Four wheel drive problems
Discussion in 'The Garage' started by nad, Jul 16, 2006.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Okay, I have a 1987 GMC Jimmy that I rarely wheel, and when I do, it's nothing but just little mud bogs, crawling over big logs, and simple pu$$y stuff. I'm sure I'm gonna get crap about all that, but anyway, when I engage my truck into 4LO it seems to randomly pop out at times. When it's in 4Lo, and I give it gas, it lags real bad like it's not engaged, then finally kicks in. Also, when it pops out, as I try to put it back into 4LO or up into 4HI, it grinds really bad and forces the shifter right back. Sometimes I have to actually turn the truck off to shift it from 4LO to 4HI or 2HI. The model of transfer case on the truck is the 208 C 2 with a freshly rebuilt 700R4 transmission. If anyone can give me any advice or diagnose my problem, I would greatly appreciate any help. Thanks in advance guys.
  2. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    when you lifted the truck did you adjust/drop the Tcase? you might need to adjust the linkage!
  3. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    No, I did not adjust or drop it at all. I thought that since it was a suspension lift and there was no body lift used, i wouldn't need to mess with that stuff. School me on it please...
  4. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Also, it did the grinding before I lifted it, so I don't know if that would have anything to do with it.
  5. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    You need to adjust the shift linkage for the t-case. The body will settle a little and move around with reltaiton to the frame over time.
    I've had to adjust this on every Chevy I've owned.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The grinding is normal I always have to shift into park to get my tcase into or out of 4LO. You can try Neutral but parasitic drag will somtimes cause things in the tranny to keep spinning and still grind in the tcase.
    Ira
  7. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    yah it sounds like a simple adjustment of the shift linkage at the tcase. I always shift into 4wheel or low when rolling in neutral. since there are no syncros on there you have to manually mesh it into gear and it will always grind a little.
    My 2cents only
  8. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Well I'm not exactly sure how to adjust it. Can anyone explain to me how to adjust it properly into relation with my 4" lift? Thanks for any help you guys can provide. I feel like an idiot.
  9. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    It is not hard. just hard to explain. from the tcase there is a shaft coming off the side that interconects with another shaft. loosen the nut on the conection joint to take the pressure off the joint and retighten. that is about the best I can describe it.
  10. justice87
    justice87 Registered Member
    Jul 19, 2006
    9
    Beale AFB
    if all fails, a haynes or chiltons can be a big help
  11. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    You was right, your lift has nothing to do with your transfer case grinding. But from time to time you need to adjust it.
  12. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Well I checked the Haynes manual on adjusting it, and all that did was confuse me even more. Can someone break it down into simple steps or even post pics? I feel like such a newbie.
