fourwheel drive indicator light?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bigmeats, Oct 20, 2000.
  1. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    is there one for my 75 blazer and if so where?
    Thanks!!
    Bigmeats
    Carl...75 Blazer...Manhattan IL
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
  3. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I have a 74 and I don't have any such light. If you are wheeling in the dark just take a flash light and shine it down on the transfer case lever and then you can tell if you are in 4 wheel drive or not! Just kidding.
    I think there is a little light under the dash right below the ashtray and above the shift lever. Mine was not wired up so I just took it out.
    Dazed and Confused in a 74 Blazer
    Zeppelin
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    I don't know about the 2nd gen Blazers, but on the 3rd gen, there is a light in the instrument cluster. All it does is indicate that a switch has closed in the transfer case. I'm not sure that the 205 and 203 even had any wires coming out of them.
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Where would the wire hook up to a 208? I had my tranny done around five years ago and the light hasn't worked since..........maybe they just forgot to plug it back in????
  6. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Yuppie light or not, I love that light. I'm very forgetfull when it comes to disengaging the 4wd. Not to mention the 205 shifter doesn't really tell you much between 2 hi and 4 hi. There's a spring loaded ball like switch that mounts on the t-case. The ball makes contact with something inside the t-case shorting the two wires. The switch just screws in in the t-case. I don't see why you couldn't make your own by just getting the switch from a salvage yard and making your own light from a LED and a 1k resister (12v bulb would work too). I had this in my 79, 80 and 87. I'm not sure what year they started this.
    BTW- 79 had a 203, 80 had a 205, and the 87 had a 208. My 87 K5 now has the 80 205.
    Shawn
    87 K5
    http://www.off-road.com/chevy
  7. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Its the same part number for the 205 or the 203 it replaces the detent ball, spring and plug.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  8. Grim-Reaper
    7,385
    Atlanta
    75 didn't have a light as far as I'm aware. My 75 has no wires or bracket to hold the switch. Now somewhere around 77-78 the 203's got a light to let you know the center diff was locked. it is controled by a button on the shifter. My 79 has it. The button looks pretty close to the button from the brake lights under the dash. it has the same locking collar deal to adjust it that always gives it up after a few years. Small radiator clamp fixes both the shifter as well as the brake light switch.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  9. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Found out that I've got one when I pulled the dash apart last week. Figured I'd try to locate the sensor this weekend to see if it will work. One of the many pleasures of a used 4x4 is the neverending chance to fix things!
    Smitty
