Frame Beef....Pics
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Apr 2, 2001.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Ok, what I'm currently in the process of doing is a motor swap. While doing that I was able to get a good look at the rivets holding the front shackles onto the frame, the body mount supports, and the crossmember. The rivets were in very sad shape (heads were loose, some rivets were shearing) so I removed them all, opened up the hole 1 size to 7/16 and installed 7/16" Grade 8 bolts all around along with stitch welding everything for added strength. Also in the process of welding on ORD's weld on kit for the steering box area. Going to be installing another crossmember in front of the stock one on the frame where the leaf spring eyes are directly under. All this together should equal Frame Beef for the front end. Lemme know what you guys think or if you have any questions I'll be glad to help out.
    <A target="_blank" HREF=http://www.pacificnet.net/~waxer/CurrentProject/>http://www.pacificnet.net/~waxer/CurrentProject/</A>
  2. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    Right on, looks solid, why can't I have a guy like you for a neighbour, mine drives an f-150 with 38 in. gumbos! I guess you don't have to drive her to work in the morning,eh!?
    Denis
  3. Waxer
    1,857
    Long Beach, CA.
    ahahah To be honest I just started welding about a month ago too. Yah I'll be using the ORD steering brace as well so I'm hopin this will keep things stout for the rock crawlin I love to do.
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Looking good. I think it will hold up fine.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    mmmmmmmm beefy lol looking good
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  6. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Gotta love them Grade 8 bolts. I just feel more manly when I go to the hardware store to buy them.
    '73 K5
    Chevy good...Ford bad
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Sounds like a plan!!!Also if you added a full cage that went into the engine compartment, that would stiffen up the frame.
    The one bad thing with the new crossmember by the front springs hangers is you will loose a little ground clearence..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    " Ah.. Hong Kong, home of shiny green suit!"
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    i re-read your post and for some reason when I first read it i tought you were going to put the new crossmemeber done between the hangers, sorry.
    Are that nuts you used on the frame lock nuts or did you use lock washers?
    Mike [​IMG]
  9. Waxer
    1,857
    Long Beach, CA.
    yah, the new crossmember will actually be higher than the stock one right behind it. The nuts are normal nuts with regular washers. I used locktite on the threads and tacked the nuts to the frame.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    10-4... I looked through all your pics, the project is looking good!!!
    Mike [​IMG]
  11. Waxer
    1,857
    Long Beach, CA.
    Thanks man, I'll continue to take pics of the progress and especially of the finished product. If its something people want then I'll do another write up on it. Also have my 14 bolt skidplate I'm working on out of 1/4" plate. Will have pics of that up soon. Thanks for all the compliments.
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Now why didnt the factory do this in the first place? Guess rivets were alot cheaper?
    I saw where you used the frame brace. Those thin steel plates that sandwich between the frame and gear box. I have one of those brand new in the cabinet in my garage. Never did get to installing it on anything I have. Anybody interested in this two piece brace? It requires minor welding.
    Anyways, good job on the beef up job! Now you can take all the other rivets out of the whole frame and replace those with grade 8's also!!! Have fun doing that! LOL!
  13. Waxer
    1,857
    Long Beach, CA.
    To hell with that :) Those 32 rivets kicked my butt. I'll replace on a need to basis. eheh
