frame bent/cracked
Discussion in 'The Garage' started by dheavychevy38, Apr 6, 2005.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    ok i need info on how to fix my broken and bent frame on my k5 it is almost straight up from the front spring rear hanger. I found this upon putting on my crossover to night and found the frame is cracked and bent and when i was driveing home tonight you could here it pop need ideas on how to fix thanks?
  2. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    V the crack with a grinder and lay a very good weld. then you may want to even plate either side of the frame over the crack.
