frame brace
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDELBLAZ, Mar 17, 2000.
  1. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    has any one ever installed the frame brace from offroad design if so will it help my problem what seems to be happening is the frame the whole side where the box is is flexing alot and i do have the plates welded on it but now its macking a popping noise when i turn or flex the suspention a bit need your opinions or addvise
  2. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    With the noises you box is making still even after having more steel welded onto it, I'd think that the holes are already enlarged. You may beable to try the ORD brace. Another option would be to take a welder, fill in the parts of the holes that are oblonged and weld flat again.
    Corey
    88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  3. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    The brace is a good investment, but first you need to find out exactly where that poping is coming from. If you don't, you may be just prolonging the inevitable.
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I occasionally get a popping noise too. I dont have any braces whatsoever and I run 35's so it looks like I need to pull the gear box and inspect the frame in that area eh? doh!!!
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Guys, spend the time checking out that sound, flexing, etc. MAKE the time. I learned about 6 years ago the hard way, my 75 (with a 454) had that problem, thought it was something minor, finally pulled my head out of my a$% long enough to crawl under it one day, found the frame almost totally sheared off from cracking that had gone on wayyyy too long. Instead of a simple bolt/weld on patch kit, I had to replace the frame in that section! NOT fun and NOT cheap. Check the frame, get the ORD gusset and put it in. Money well spent.
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  6. Jason73K5
    592
    Fresno, Ca
    BlazzinOR is right, if you don't check it soon, it will bite you in the butt at the worst possible time. I know from experience too. My frame broke completely about 100 miles into a trip from Virginia to California. It made for a very interesting trip!
  7. Hobbes68
    Hobbes68 Registered Member
    Mar 20, 2000
    80
    Yonkers, NY
    When I got my truck, it also had a welded frame reinforcement plate, but the steering box still moved around. I drilled out the steering box mounting tabs and rethreaded them to accept larger bolts that fit snugly in the holes in the frame. 2 + years later and no problems. Even still, I plan to install the ORD brace when I get a chance.
