Frame crack repair progress and one question..pics..inside
Discussion in 'The Garage' started by TJS, Sep 22, 2003.
  1. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    As you can see by the pics I have been busy working on this truck. Here is my question. The engine cross member is riveted in so I decided to weld the edges of the cross member to the frame. Also I did the same with the front most cross member as well and welded some angle plate to tie in the frame and the front cross member. Then I looked at where the springs mount to the perches in the front and they are riveted too. Should I weld these to the frame as well. Also the front cab mounts (above the perches) are also riveted in. Should I weld these in as well. I know some flex is good but I hate rivets. Thanks. See pics of progress. [​IMG][/url]
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Id grind the rivets off and replacethem with grade 8 bolts. I did it to my front crossmember and im thinking about doing it to the rest of the frame butt itll be alot of work.
  3. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    grade 8!!!
    welding to the frame isnt a good idea when the holes are already there...the previous owner of my truck decided to weld the transfer case crossmember to the frame for added support. what a pain in the asss when it had to come out.
  4. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    The rivets are still in their place. I figure that the crossmember has been there for over 17 years so it is not going anywhere so why not add some strength and support to them. If I have to ever remove the crossmember then that is what my plasma cutter is for. Yes drilling out the rivets and replacing with grade 8 bolts is a good idea. I may do this but while I have the engine out I think getting in there and welding will be a little easier right now.
    T.J.
    www.tjsperformance.com
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Not to cut you down or anything, but you've got some serious cleaning to do before you weld anything.
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Rivets allow the frame to move a little w/o tearing stuff loose like welds can do. I'd leave the rivets alone except where you need to remove them for some mod.
    Same for welding x-members in. Unless you can structurally reinforce the whole frame so that it's one rigid piece I'd leave them alone. Bolt any braces in place.
    Fish plating cracks is a different deal. Try not to cut the plates with edges that are straight across the web or the flange of the frame, cut them at angles or even do a flat 'fishmouth' to them. The idea is to not create new places for cracks to form.
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Take a closer look...he's already welded.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I do see clean metal so I assume there's welds there. My eyesight isn't THAT good.
  9. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    wow dude, that looks like a nice braceing job, i decided to brace my frame too due to rust, stupid rust, but looks good to go /forums/images/graemlins/thumb.gif
  10. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    Yes I grinded the spots to be welded. From the pics it looks all rusted but I made sure the weld points are clean with a nice grinded surface. Also when I cut my steel I square it up on the Bridgeport Milling machine when I can.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sweet dude. When you doing mine?
  12. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    Wow, you should not have a welder! /forums/images/graemlins/rotfl.gif
