Frame Crack Welding Info Wanted
Discussion in 'The Garage' started by landsmasher, Jul 21, 2002.
  1. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Doing the Steering Box Frame Crack thing. My question is, when doing the V groove thing to the cracks in the frame, how deep and how wide should they be? What should I look for while doing it? And then how far should I grind it all down to the frame surface?
    Just trying to get it right the first time... /forums/images/icons/tongue.gif
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I wouldn't go much deeper than half the thickness of the frame- Maybe alittle more. Just don't go so deep that you burn holes when ya weld it. As far as how wide, Just to make it simple, just go as wide as a grinding wheel. Are you installing the steering brace thing too? If your doing that, grind it down flush with the surface of the frame. If not, and it won't interfere with the mounting of the steering box, I'd leave it.
  3. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    I would use a regular grinding disc and 'V' groove the crack just over half the thickness of the material. Weld it up and then do the same to the backside if you can. If there is little or no acess to the backside of the cracks then grind a little deeper. At a little over half the material depth you should get 100% penetration or very close to it.
    If you need to grind it flush be carefrul not to grind into the surrounding 'parent' material'
    Rene
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    If I could think what name of it is. Tool looks like an acorn shaped drill bit, used to port heads and what not. We used it to make a nice clean path then welded it up.
  5. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    That would be a carbide burr for a die grinder. They have many shapes and sizes too. I have one that's like a ball about 3/8" diameter and another that commonly known as a 'rats tail'. Kinda conical and comes to almost a point. They would work well on a Dremel tool too.
    Rene
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    What are you gonna use to weld it?
  7. landsmasher
    Mar 13, 2002
    4,423
    I'll be using a Lincoln wire welder. Flux core wire... I can't install the steering brace because I have a PTO winch and the drive shaft for it is in the way. I'll check out the die grinder thing... Thanks Guys! /forums/images/icons/grin.gif
  8. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    Dont forget to drill out the ends of the cracks or they will come back!!
