Frame Crack
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Jul 11, 2000.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Ok we all know about the crack chevy's get right under the steering box. This happened to my old truck. My question is is it the width or weight of the tires that does it? I'm pretty sure it's the width, because there is more grip. The reason I'm asking is as soon as I can find a cheap set of 15x10's I'm gonna add my new tires ( 31x13.50). And I wanted to know if I should take some precaution. Anyone know what exactly causes it?
    89 K5 Silverado
  2. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    I am not to sure what causes it but if you plan to modify your truck in the future, you should re enforce or install a brace now.
    <font color=red>Chevy4x4<font color=red>[​IMG]
    http://fourbyfour.coloradok5.com
  3. chevy4x4
    Apr 27, 2000
    1,454
    I've hears people say that it doesn't happen when the truck is stock but I also heard other people that say it happens when the truck is stock too.
  4. Grim-Reaper
    7,385
    Atlanta
  5. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Well the frame at the box is fine on the Knight, but the crossmember at the engine mounts is cracked right at the passenger side motor mount, first time I've heard of this one.....this weekend the welder gets dusted off.[​IMG]
    <font color=blue>White Knight</font color=blue>[​IMG][​IMG][​IMG]
  6. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    someone correct me if i am wrong, i think due to the weight of the truck, with turning the steering wheel, the steering box is pushing against the frame and kinda twists it. the problem comes when you lock the steering wheel to one side and hold (also ruins the pump and box), add large tires (more strain to turn). also the steering box bolts have a habit of coming loose, this makes it worse.
    Knife.
  7. Eric78K5
    Eric78K5 1/2 ton status
    Feb 18, 2000
    230
    South Carolina
    I haven't heard of stock one's having this problem. My 78K5 has god only knows how many miles on it, and my steering mount is still ok. But it's only had stock size tires on it. I'm going to do the upgrade before I add the lift and 35's!
  8. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    When it cracked on my old truck I was running 35x14.50 Thornbirds, so needless to say with the grip I had on the road with them things it was gonna crack. But the MT don't have anywhere near the grip those things did.
    89 K5 Silverado
  9. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    My 75 I had a few years ago did it big time - factors at work - 4" lift, 35" tires, 454 motor with a lumpy cam, and a heavy right foot. THink it is a combo of all things, seems the lifts create more leverage on the frame, and the steering boxes twist the frame.........not a good thing. On that one, I had to graft in a piece of the frame, was too far gone to repair it. Fix it now.
    <font color=black>'79 K5 - 406 w/IROC TPI -<font color=orange> K5#5 - <font color=blue>http:// www.blazzinor.coloradok5.com
  10. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Well it's not broke. I was just wondering if I should take precautions on my stock vehicle before I put my new tires on. I deff. will add it one day If I ever get a lift and some 36".
    89 K5 Silverado
