Frame cracked at power steering box
Discussion in 'The Garage' started by K-5krazy, Aug 7, 2006.
  1. K-5krazy
    K-5krazy Registered Member
    Nov 15, 2005
    31
    Hattiesburg, MS.
    Not long ago my frame was cracked right by the power steering box, so I freaked out wondering what to do. I got on the internet and found a piece that bolts to the frame by the power steering box and over to the cross member bolting to it. This is supposed to keep the power steering box from pulling and pushed on the frame when i turn, which makes the frame crack. Of course I welded the frame back together before I put the piece on, but now my truck is really out of align, and I am afraid it still might crack again. Is there anything else I can do to help this problem. I have a 1987 K-5 Blazer with 36"s and a Dana 60 up front if that makes a difference on suggestions somebody might have.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If you are asking about the alignment, I have no idea and would bring it to a body shop. The frame braces are here and if I had a crack I would use both.
  3. K-5krazy
    Nov 15, 2005
    31
    Hattiesburg, MS.
    frame questions
    Actually that is the brace I used, I wondered if there was not something else i could use as well to help strenghten the frame or another device that went with the steering comnponents to create less stress. Mabey I did all I could do thanks for the reply.
  4. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Use both braces. The weld on and the bolt on. That's what I did.
  5. K-5krazy
    Nov 15, 2005
    31
    Hattiesburg, MS.
    weld on
    Oh Ok but where do I find the weld on bracket at is there a websit or somthing. thanks for your help
  6. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
  7. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    right below the bolt on one.
  8. K-5krazy
    Nov 15, 2005
    31
    Hattiesburg, MS.
    Oh I see it. thanks for all you help I will definentley see about getting that brace. Hopefully it does not matter what order you put the brakets on since I already instaled the bolt on bracket first
