Frame cracks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hossbaby50, Sep 1, 2001.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I broke the piece of frame off on my 85 jimmy were the transfer case crossmember bolts to the frame on the passenger side. Has anyone else had this problem? Were else should I be looking for cracks beside the steering box? thank you
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Thats mostly caused from bashing the cross member into a lot of rocks. Most Blazers/Jimmys just crack at the gear box.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Check around the rear shock mounts, the front body mounts, the t-case (you already did), and the firewall body mounts. when you go to repair the frame, make sure you get a piece of slightly larger channel, and box the frame on both sides of the crossmember.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Or could have from the bolts being loose. I would check/tighten every bolt on your Jimmy. As they get older alot of the bolts start to come loose. The dont get rusted tight here in AZ.
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Those crossmember bolts will rust here - 3 of mine were rusted down to nothing and snapped, with the 4th pretty close to failure.
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I have yey to find a bolt that is rusted on my Jimmy. Its is an original Az truck that has sent its life here in Phoenix. Your up in Kingman. You guys get snow.
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I took it to the guys at FST, Flyin' Highs fab shop and the welded a new plate over the area and up the side of the frame. It looks stout, so I'm not that worried about it, should I be?
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    If FST did it, you have nothing to fear - those guys are awesome!
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I think it broke partially from bashing it on rock, and its been wrecked and the frame tweeked. The frame was straightened and everything was okay until on day when I was camping and I found that my transmission was hanging half way out of my truck 70 miles from home. It was my first real trail fix and I got home so I was pleased. On the piece of frame that cracked of I could see where it had cracked in the past and where it broke off that day.
  10. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the crossmember under the engine is always cracked under the fuelpump.
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    thats the problem with my blazer. it started out in WA, then moved to OR, then i had it in CA for almost 3 years, now it is in AZ. she has a bit of rust. not much for where it has been though.
    Grant
    oh yeah, do check your rear shock mounting points at the frame. i dont have any shocks cus i didnt. the drivers broke out of the bracket and the pass elongated the hole from not having good bushings on the bolts.
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
