Frame crossmember rivets??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bckinblk, Sep 25, 2002.
  1. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    I was under my k-5 and noticed that I busted 2 more factory rivets .Would it be better to drill out all of them and replace with bigger grade 8 bolts ??or weld them together?? I was thinking of using 1/2 inch bolts has anyone done this?? does it solid up the truck??? thanks for any info in advance.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    drill them out and use the grade 8's and forget about it /forums/images/icons/smile.gif
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Yah...I agree....and use locking style NUTS......RED Lock-tite and You'll never have a worry!! /forums/images/icons/wink.gif
  4. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    I would definately suggest you use ny-lock (sp?) nuts. Won't have to worry about them being tight anymore.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I have drilled out and replaced most of the rivets in my rig now. Mostly due to getting rid of things I don't need, or moving things like the suspension and cross members. I replaced them with 1.25" x 0.375 G5 bolts, flat washers, split washers, and nylock nuts. These are a perfect "bolt on" /forums/images/icons/laugh.gif (i.e. fits the rivet hole exactly) replacement for the rivets with double or triple layers of steel to go through. I did not Lock-Tite mine but, if I knew it was not going to be moved, and it was a daily driver, I would probably add that just for piece of mind.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Grade 5 or 8 will be fine. You can use a 3/8, but it would be better to drill out the hole for a TIGHT fit with either 7/16 or 1/2 bolts. I prefer pinch lock nuts, I have NOT had good luck with ny-locks. Flat washers are also a good idea, especially on the nut side. I would check the torque on them after running them for a month or so, then locktite 'em.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    that is what mine is done with.
    I have heard them refered to as 'stovers' nuts
    last frame was welded
