frame cutting
Discussion in 'The Garage' started by 1986chevy_rider, Dec 8, 2006.
  1. 1986chevy_rider
    1986chevy_rider Registered Member
    Nov 8, 2005
    97
    fallon nv
    Well Im thinking about taking my bed off and cutting my frame to the rear of the leaf springs is this a good frame mod what do I do to finish the frame if anything thanks
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you will need to make new mounts for the bumper or add a new crossmember at the new rear of the frame
  3. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I am doing exactly what you are talking about. Frame has about 2.5-3" past the shackle hanger. I have a big piece of 4x2x0.25" wall tube I am going to weld into the resulting "hole" that will serve as "bumper" and crossmember. Of course, if you do this, you won't be able to keep your gas tank in the stock location. I'm going to a cell mounted higher up, so I don't care... but something to think about if you still have the stock stuff.
    j
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    he doesn't have to worry about a gas tank. If you are taking a bed off the you have a pickup. not a blazer or suburban. Definitely add some type of crossmember to stiffen it up afterwards. If you've got skills then this would be a good time to make a custon bumper with a reciever and some D rings. good luck and take lots of pics.
  5. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    allright thanks for the help. and yes it is on a truck and I was thinkin of going to a fuel cell anyways on a custom flat bed that I want to build.
  6. goldwing2000
    goldwing2000 Guest
    Might want to box in the rear half of the frame while you're in there.
  7. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    If you`re going to box the frame at all, do it all. If you do only the rear, all it will do is give you a weaker link in the frame.:deal:
  8. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    strengthening one spot does not make another weaker. Any boxing done makes the overall strength higher. twisting and flexing is what weakens frames. if you eliminate flex over half the frame then you have helped cut down flex over the other half.
  9. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I agree with everyone that says you have to build a new crossmember back there, but would add one thing. Run some braces from the new crossmember about 5-10" back on the frame. It just stiffens things up a bit. If you have the abliity or the time put another crossmember up by the front of the springs with the same style gussets. I have done this very thing to one truck it really seemed to stiffen up the frame.
