frame difference
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by edgy1, Jul 25, 2002.
  1. edgy1
    edgy1 Newbie
    Jul 25, 2002
    I need to clear something up. From what I can find, the frames on the 73-91 1/2 ton Subs are the same as the 3/4 ton. The difference between them are in the brakes and axles. Is this true? Or is their some tie in with the 1 ton chassis?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yup, that should be the case. The 1/2 and 3/4 ton trucks share the same frame, the 1 ton is the only one that's deiiferent. </font color>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, what Shaggy said.../forums/images/icons/wink.gif
  4. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    I've got a factory options sheet for my 91, and it does list some differences in the 1/2 - 3/4 frames. Not big things, but thickness .177 vs .192 section radius 3.57 vs 3.88 RMB (??) of frame/Lb-in 139.230 vs 151.320
    Dimensions seem the same however, but guess those little things help give the 3/4 ton the higher weight ratings.
