Frame Difference:
Discussion in 'The Garage' started by conoverbandit, Mar 3, 2004.
  1. conoverbandit
    conoverbandit 1/2 ton status
    Jan 23, 2002
    452
    Conover N.C
    Looking to trade with a fellow member for a crew cab 4x frame but it is SRW (single rear wheel) I have a Dually 2x that I want to convert. My question is this: will my Dually axle work on the Single frame or is the Dual frame narrower?Thanks,
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the frames should be that same. the spring brackets are even the same
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    The frame itself has nothing to do with the width of the trucks. Its the rear spring hangers that are different between the C/K20's and 30's. 30's hangers are narrower, hence the reason the perches are closer together. Your rearend will fit as a direct swap in since both frames are 1 tons. /forums/images/graemlins/waytogo.gif
  4. conoverbandit
    Jan 23, 2002
    452
    Conover N.C
    Cool,
    Thanks for the info, I guess I need to get up with bushwacker now and finish setting up our trade /forums/images/graemlins/thumb.gif
    Oh boy is the wife going to love this parts run...................... /forums/images/graemlins/eek.gif
