Frame differences 3/4 vs 1 ton
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dremu, Oct 12, 2004.
  1. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    Yeah ... I know it's sorta been covered before, but I have a twist. See, I heard this rumour that sixpacks /forums/images/graemlins/crewcab.gif (at least in the early 70's, like my '74) all had a 1-ton frame, even if they were 3/4 ton. Being the curious type, I wanna know if this is true.
    So I found this page which lists a boatload of different frames and dimensions, but it's so complicated it makes my head spin. I *think* I have an answer and my truck is the CA314... but I'd love to hear any ideas there.
    However, I did take a couple of comparative measurements between the pickup in question and my Blazer (also a '74).
    I note the Blazer frame is ~1/8" thick, at least on the bottom edge I could get at conveniently, and the pickup is much thicker -- like 3/16".
    I also note that my 14-bolt has springs which are 39 1/2" center to center, but that just prolly means they're your usual 3/4 ton springs. The Blazer's gas tank and skid plate are in the way, or I'd compare it to the Blazer.
    From the frame thickness, I'm inclined to believe that it IS indeed a 1-ton frame ... can anyone prove or disprove this?
    And finally, am I supposed to measure springs and perches center-to-center, or outside, or ... ?
    -- A
  2. virgilh
    virgilh 1/2 ton status
    Sep 8, 2004
    343
    Sacramento California
    if you measure the height of the frame i'll compare it to my k30 thats the difference of 1/2 3/4 ton frames to 1 ton frames also the thickness of the frame but im not getting under the truck with a set of calipers /forums/images/graemlins/thumb.gif
  3. BigBlockBurris
    BigBlockBurris 1/2 ton status
    Jul 27, 2002
    100
    Concord, NC
    Every crew cab I have ever seen has had a 1 ton frame. I parted a 74 and it was a 3/4 ton but it had a ton frame. I read somewhere (I can't remember where) that all crew cabs were ton frames regardless of suspension rating. Hope this helps.
    BBB /forums/images/graemlins/crewcab.gif
  4. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    [hijack]
    Has anyone ever bobbed a K30 frame in the right places to make it fit under a K5?
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The shape is all wrong to easily fit and would require extensive modifications to the K5 tub.
  6. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Thought it might be a little better as too torsional loads....
    I always thought a K5 was based on a shortened K10 frame, and that was why there was a 6" rise just behind the front seats? /forums/images/graemlins/confused.gif
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Early second gens would be easier, later tubs have a rear foot well that would need channeling. IIRC, the pickup version rises higher and further forward (actually under the seats, not behind), and the body mounts past the fire wall are different.
  8. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Doesn't that mean tha a crew cab would raise far enough back to make it work?
    I'm not talking about just cutting off the end & calling it done. I had assumed some would have to come out of the middle, maybe even shorter cross members /forums/images/graemlins/ears.gif
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    crewcabs were all 1 ton chassis yeah
    1 ton has taller frame rails than 3/4 and 1/2 tons do
    in 68-72 there was a model called the longhorn pickup, they were only built 20 and 30 series, both used the 1 ton chassies, so there was a 3/4 ton being built at factory using a 1 ton chassis but was badged as a 20 on purpose, even the spring packs were 40 apart
    youre measrugin 39.5 but its stillt echnicallyh 40 no matter what you call it or think it is, gm only had 40 and 42.5 pack spacings been this way since at least 63 or 63 on all the trucks 30 series and under
    same with the crew cabs 73-up you could get a 3/4 ton crew cab but it was a 1 ton 40 apart spring pack chassis of course(none factory built until after 72 some time)
    also the R03 dual real wheel conversion package was available for 20 series trucks ofr at least 67-72 years, dunno about before or after
    i can list technical details straight from gm model year options sheets for most of these
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sorry, don't know the answer to that one. Do some measuring and let us know. /forums/images/graemlins/laugh.gif
  11. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    don't mean to hijack but since 1st gen. frames have come in to the conversation here goes. randy of all the people that know 1st gen stuff you seem to be the one that knows most. /forums/images/graemlins/bow.gif my 4x4 is a 1967 gmc camper cruiser. it was a 3/4 ton 2wd had the rear d60 axle when i pulled the body off frame i was impressed at how the frame had factory gussets at every crossmember. spring spacing was 42.5 and leaves in rear were 9 ever heard of one of those? thanks lonnie /forums/images/graemlins/dunno.gif
  12. dremu
    Feb 27, 2000
    15,952
    443
    Oh, no argument from me -- that's sitting in the fricken street, so I wasn't gonna quibble over fractions of an inch! /forums/images/graemlins/laugh.gif
    Hmmm... soooo if I got bored someday, I could drop in a set of springs off a 1-ton in the rear ... any idea of what's different in the C30's (i.e. 1-ton 2WD's) up front ... ya think the rotors and stuff are the same? coil springs prolly are bigger on the 30's... anything else?
    -- A
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    2WD front suspension is identical on 3/4 and 1 ton trucks. Only significant diff is that the 1 tons have a dually spacer. Springs, A-arms, spindle, even the cradle are all the same.
  14. dremu
    Feb 27, 2000
    15,952
    443
    Okay. Finally I had a combination of ffee time and no rain /forums/images/graemlins/waytogo.gif
    I measured the frames just in front of the rear axle in the wheelwell, as it was a convenient place to get to the frame ... and the ends taper by the bumpers, I suspect.
    The /forums/images/graemlins/k5.gif frame is ~6" tall, and the /forums/images/graemlins/crewcab.gif is ~7.5", so I'm gonna betcha your K30 is the same.
    Randy-san, do those measurements sound about right for the taller frame on a 1-ton?
    -- A
  15. dremu
    Feb 27, 2000
    15,952
    443
    Cool! Now, I don't think that *all* one ton's were duallies (nor were all 3/4's SRW ... pretty sure both GVWR's came in both wheel types) ... but that's good info. LMC doesn't touch the 30-series, and my real Chevy books are still boxed from the move /forums/images/graemlins/laugh.gif
    Thanks! /forums/images/graemlins/waytogo.gif
    -- A
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I thought all C30s were duallys, and the only C20 duallys I've heard of are the pre-72 trucks. But I could certainly be wrong on that.
    I'm sure about the rest though since I once made quite a bit of coin converting old drum front trucks to disks, including several C20/30 trucks. My old 69 GMC 11k car hauler got a complete front cradle from a 78 3/4 ton Chevy to upgrade suspension and disk brakes to more common, cheaper and easier to find later model components.
  17. dremu
    Feb 27, 2000
    15,952
    443
    Well, rooting through the brochures, I see lots of "Dual rear wheels are available" ... but only for 30-series, so by the looks, we're both half right. No 3/4-ton duallies (at least, say, 73-80ish) and 1-ton's were available in both.
    Sweet! That makes my life easier, as it just means I could conjure a set of the 1-ton springs, and beef up the old girl nicely.
    -- A
  18. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have a set of the one ton springs if you feel like paying shipping, they are free
