Frame differences
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blasterD, Apr 20, 2004.
  1. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Is there a difference between a 1/2 ton frame and a one ton frame? I am aware of the differences in the rear (rails are closer together), but is the metal any thicker or stronger? /forums/images/graemlins/ears.gif
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The front section around the motor appears to be the same. The rear is not narower, it's the spring hangers that are different. The section under the cab is deeper,something like 11" compared to the smaller 8" section on the 1/2 & 3/4 ton frames. As far as actual metal content or thickness I don't know.
