frame flex pic link
Discussion in 'The Garage' started by original balzer, Jul 31, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    is this a normal amount of frame flex for these big GM trucks?
    pics
    look at the body line on the 2 poser flex pics 2nd and 3rd from the top. the picture dont look as bad as real life though. this seams exessive to me and makes me rethink using a body lift.
    balzer
  2. dyeager535
    26,979
    Fixed pic link
    Yep, those are abnormal alright. Not enough difference in body lines. :)
    Seriously, that's not much, and is probably average based on how you had the trucks for the pics. Depends how twisted up you get the suspension.
    When you hear the roof wrinkle, you know you've pretty much maxed out the frame flex lol.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Frame flex??? The body lift really tends to exagerate it. In the two pics taken from behind you can see how much the bed if off from the chrome strip on the back of the cab.
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Dude, you ain't got no body mounts left. It looks like the underside of your box is swiss cheese. It shouldn't rhombus that much, especially with the tailgate on.
    Now if you don't have a box or a core support tied to the cab there is a lot of frame flex (or, if you have two hockey pucks for a body lift). It doesn't matter if the frame is only 15' long or that it is structurally solid. There is nothing to tie it all together. Even new trucks with their hydroformed frames twist. It'll still suffer from wet noodle syndrome with nothing tying it together.
  5. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    :eek1: Yep. Would have been hard to tell without that chrome strip. :D
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    is there a place to get new factory body mounts, or do you have to go with a BL to replace them?
  7. dyeager535
    26,979
    Rubber ones you can probably get from LMC or even GM, but cost-wise, poly is probably a cheaper route to go.
    No real disadvantage to poly body mounts, some people notice a rougher ride, some don't, that's about it.
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Urethane ones squeak, transfer just about every pebble in the asphalt to the cab, and aren't much cheaper than GM OEM. My friend put Energy Suspension on his truck and it squeaks. It also is like riding in a unibody car... you feel everything and the road noise is atrocious.
  9. dyeager535
    26,979
    Like I said, results vary. My truck doesn't squeak, and the ride is no worse than before.
    Noise=movement, body mounts shouldn't be moving.
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    They're supposed to move... otherwise there would be no rubber bushings. Not a lot... but maybe a quarter inch in either direction. The squeaking always seems to come from the lower half. I've seen them squeak on auto parts store ones also. The lower ring of rubber squeaks on the metal cup if I had to guess.
  11. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I've seen alot of flexed out pickups. That is FLEXED. But it is normal. I seen new pickups flex almost that much.
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Did you lube them with the special formula lube that comes with the bushings? That lube is sent with the kit for a reason, you know. :thinking:
  13. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    does the lube stay there forever or..? maybe it dryes out after a couple years
    make them greasable ! put in a grease fitting or something
    what happens with a blazer when it flex ? since the "bed" can't move like a truckbed can?
  14. dyeager535
    26,979
    My energy suspension body mount sets didn't come with lube.
    When Blazers flex, the roof wrinkles, and the doors bind up. Also, the topper splits along the seams at the back window.
  15. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Here's my .02
    I've been on some SoCalBigDawgs runs with my brother...he (obviously) has a K10. I think a shortcab truck has an advantage over a blazer, SUV, Xtracab like my Dodge in that the cab and bed are separate and the cab is short. His body mounts are still dying tho (see his album and you'll know why). The back of the cab where the 2 mount are is slowly collapsing.
    I have a Jeep CJ-7 (let the flaming begin) :D which as far as the body goes is like a blazer but smaller...I had a body lift on it and wheeled the pee out of it for years - we live in the middle of tons of 'froadin' and there's not much else to do here. Almost all of my body mounts are trashed, either punched thru the body or torn off it. I recommend using stock mounts (no body lift, cut your fenders!) and installing the bolts not-too-tight with some threadlocker to retain them.
    Ideally (this is what I'm going to do, saw it in a mag) I think the bolts should have a spring (I've heard old valve springs work) under the head to allow it to pull up when the body and frame want to flex away from each other. A spring on top may help too, but it might allow the bolt to "wobble" too much and rip out the nut in the body. BTW, all the big water trucks, etc. that come thru our shop have the tanks, bed whatever mounted to the frame this way. Sometimes you can't make something strong enought not to break, so ya gotta make it flex. Kinda like secondary supension or something .
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    Weird. Mine did. I noticed ES packages have been shipped in boxes lately and not in the "bubble wrap on cardboard" packages for me. Wonder if that had something to do with it?
  17. dyeager535
    26,979
    Both my sets came in the cardboard boxes.
    Can't complain about my mounts so far, have them in my car and truck, don't hear either one, which are not lubed.
