frame measuring...
Discussion in 'The Body Shop' started by 90blzr, Dec 14, 2004.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    whats the best way to measure a frame to make sure its not tweaked? From what points do you measure?
    Thanks!
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    IIRC, the holes on the right side should be there on the left side. just measure across the frame from one hole to another then again starting on the other side (making a X) and you should get the same measurement on a straight frame. do it at many points on the frame to make sure.
  3. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
  4. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    thanks for the link. I really dont think the frame is tweeked, I'd just like to make sure. I assume the truck has to be sitting level, with nothing in the bed, etc.?
  5. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    That would help...
    But I would look for kinks in the frame...especially the front frame horns..
    and behind the front wheel...
    Doing "X" measurements works well to...most frames are within a 1/4".
