Frame Mounted Roll Cage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cocky, Mar 27, 2000.
  1. cocky
    cocky Registered Member
    Feb 21, 2000
    88
    Northern Colorado
    Has any one mounted their roll cage to their frame? If so how? I have heard this will make the cage more solid. It seems like it would since the metal floor board is pretty thin. Also i think this would stiffen up my frame and body which seems like a good idea since this summer i will take my doors off and don't want to tweak my body. Any ideas or suggestions are appreciated.
    Richard
    1970 k5 Blazer
    Don't stand in front of a train naked
  2. cocky
    Feb 21, 2000
    88
    Northern Colorado
    Even if nobody has ever done this, does anyone have any ideas?
    Richard
    1970 k5 Blazer
  3. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Being an engineer, I would not tie it to the frame.Long ago I was taught if something was made to bend, then you stop it from bending, something is gonna break. Your frame as well as the whole body is engineered with a certain amount of lateral and longitudinal torsional flex, by attaching a framwork to the existing frame you defeat this flex ability and increase the chances of something breaking.
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
  4. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    You're probably right about breaking something , but I'd rather break something on the truck than break my head when the roll cage rips away from the body.
  5. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    AS stated before, all roll cages are bolted/welded to the chassis. Light bars are bolted to the body. If you are worried about chassis flex, stress better artculation. I wouldn't worry about the flex lost by the cage.
    Corey
    88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  6. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Well, not to be arguementative, but lots of things that can bend are better off NOT bending. A good example in my industry is utility poles. Sure a pole can support a certain load and withstand a set amount of windloading but allowing it to move is not necessarily a good thing. That's why down guys and anchors are employed throughout.
    But enough of that stuff! I just found an article last night where a company (Mountain Off-Road Enterprises(M.O.R.E.))sells a kit that allows you to tie your roll cage to the frame. It includes outriggers (mounts) that weld to the frame for the cage to bolt to and includes bushings that absorb some of the flexural stresses. My opinion is that the more frame flex can be minimized and suspension flex maximized, the better off structurally the Blazer will be. My only question would be is it better to drill a hole through the body floor and allow the rollcage to pass through to its frame mount (with some kind of gasket around the base to seal the hole and leave room for cage/body flex or should the base of the cage and the frame foot mount sandwich the body between it? The M.O.R.E. kit (for jeeps) sandwiched the body between the two mounts. From what I have read in the past on this board and other sources, most people don't put a lot of faith in body mounted cages because the cage is then only as strong as the body metal it mounts to.
    Good Luck
    Brian
    Still in search of the TBI KING!!
    P.S. I am doing a frame off rebuild this summer and hope to build a complete cage that mounts to the chassis but also passes straight through the dash close to the front A pillars on either side of the window. Hopefully, it'll be documented on Colorado K5 as a project.
  7. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    What kinda rollovers are you guys preparing for??
    I don't know about the rest of you but when I go wheelin I ain't goin much more that 5mph and if my rig does roll it most likely won't do a flip right on top of the cage and cause it to punch thru the floor! The roll will be body/cage/body/cage/ etc.....
    Just a thought but the body on my rig has reinforced cross members center and rear that is what my cage bolts too and from the looks of it for the cage to punch thru it would have to be damm hard at 80mph!!
    Thats all i'm done
    Burt4x4
    Rock ON!
  8. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I agree Burt, my six-point cage is welded to 6"x6"x.125" plates welded to the floor. The plates are located above cross members. I'm not worried about my head. You might be surprised if you look through a racing tech manual like NHRA for cage requirements. They allow you to attach the cage to the floor.
    CB
