frame painting?
Discussion in 'The Garage' started by chevy_tuff, Apr 8, 2004.
  1. chevy_tuff
    chevy_tuff Registered Member
    Apr 4, 2004
    29
    B.C. - Canada
    hey, i just sanded down the frame on my 1980 chev and was wondering what would be the best paint or undercoating to use to protect it. thanks for the help
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    por - 15 works good
  3. kylo28
    kylo28 Registered Member
    Mar 4, 2004
    80
    Modesto, CA
    I just use cans of Rustoleum spray paint.
  4. husurddy
    husurddy 1/2 ton status
    Jul 28, 2001
    108
    Snow Hill, Maryland, go east \'till you hit water
    POR-15 is a pain in the butt, it's $$$$$ and the directions have to be followed to the "T". That said, once on, it stays on and wont come off, (unless you use a stripper of some sort.) It STOPS and prevents rust and I love it. I even painted an inner fender with POR-15 and two years later and a zillion chuncks of stone and mud later, it still looks great. I don't mind taking the extra time to prep and paint with it because I know I wont have to do it again anytime soon. I live in the rust belt and anything I can do to prevent or stop the cancer is like money in the bank to me. /forums/images/graemlins/thumb.gif
  5. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I used a two part epoxy paint from "international paints" on a skidoo trailer that see's nothing but salt (about 92 or so)
    (brand new , sand blasted , then paint)
    It worked awsome
    We used to have to wire wheel ,re-paint it every year , now we just look at it every summer , amazed it does'nt even get rock chips any more
    I even thought o doing a trail rig with that stuff very tough /forums/images/graemlins/whistling.gif
  6. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    por15 /forums/images/graemlins/thumb.gif my calipers,draglink,housings and motor will be done with por15.prep is a pain the arse but worth it.
  7. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    if it'a a bare frame have it powdercoated. not really that expensive. last one i had done was $250 i think, plus it's pretty durable.
  8. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  9. chevy_tuff
    Apr 4, 2004
    29
    B.C. - Canada
    where do u buy por15?, thanks for all the help by the way.
  10. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  11. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    How much paint was required for each coat? Don't want to buy more of the POR-15 than I'll use on the frame.
  12. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I used a quart of POR-15 and a quart of Chassis Black. But I think I used some for my axles too. For both quarts you are into it for less than $100 for the paint but if you buy their prep products, it would run just over $100. Considering how hard the paint came out on my frame, it was well worth the time and effort to save myself the bucks that I would've spent on powdercoating. In fact, I overpainted the area that I was going to weld in my frame brace. I tried sanding, wire brushing, paint remover, but nothing made a dent in the paint. I finally had to take a grinder to the paint to get back to bare metal for the welding. I've wacked on the paint with a hammer and it doesn't phase it. However, I did follow the instructions to the letter, including prepping it by stripping all oils off of it with their Marine Clean, and then spraying it with their Metal Ready. I'm using it on my axles, front Crane High Clearance D60 diff cover, and I may use it on my bumpers as well.
