Frame prep
Discussion in 'The Garage' started by 1979jimmy350, Mar 28, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    What is the best way to prep a rusty frame for paint. What would be the best way to remove the rust and prevent it from eating through the new paint?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Absolute best: Acid dip /forums/images/graemlins/yikes.gif
    Pretty good: Sandblast /forums/images/graemlins/woot.gif
    Acceptable: Wire brush and elbow grease /forums/images/graemlins/waytogo.gif
    There are a lot of products out there for rusty metal. I believe POR15 is meant to be used on a rusted surface. If the paint you use (be it tractor implement paint, or whatever) says to have a rust free surface, scrape off all the loose rust, wire-brush it, and then use a rust-converting product (naval jelly rust dissolver works well) before you paint.
