Frame prepping for undercoating, paint,....???
Discussion in 'The Garage' started by Zepplin, May 7, 2002.
  1. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Well, I have my body off my frame so I have great access to start cleaning it up. I figured I would use a wire wheel of some kind to knock off the surface rust. I looked over briefly where the steering box was mounted (its off now) and didn't see any cracks.
    Anyway, this isn't going to be a show truck but, I would like to apply something on it. I really don't want anything too nasty like undercoating on it or anything. I read where Por15 can be put on alot of surfaces but, does it have the same consistency as undercoating? Or is it a smoother texture.
    I would like something that would clean up easily after a weekend of wheeling in the mud.
    I just figured I would get everyones opinions on what they would do to clean up their frame.
    So what would you do?
  2. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    POR 15 can be as fine or lumpy as you want it to be, but it isn't anywhere near undercoating or bedliner. I've seen it as smooth as any paint a body shop could do, or all rough and textured where someone put it over some scaley rust with a brush. First was on a hot rod, second was on a 4x4.
    I'm thinking POR 15 THEN bedliner stuff./forums/images/icons/smile.gif
  3. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I cleaned the bottom off with various sized of wire wheels. I coated the bottom with POR15 to seal and prevent rust. I then applied rubberized undercoating. Ideally, I would have sprayed bedliner, but the undercoating is fairly tough and can be touched up easily.
  4. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    Thanks guys. I went to the POR-15 site and they have alot of different products out there. Would a gallon be overkill if I wanted to do my entire frame and some other stuff? It said it was $88 for a gallon. I'm sure I could find some other places to put it on.
  5. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    I hear of guys doing LOTS of stuff with only a pint, but hell, with a gallon you could do the frame, and at least a lot of the body. This is Michigan after all./forums/images/icons/tongue.gif When I get my K5 I'm gonna do something, probably POR 15 and Herculiner, to as much of the metal as I can.
    No rusty!
  6. Zepplin
    Aug 29, 2000
    920
    Bay City, MI 48706
    I was thinking the more the better. I was thinking of doing the Por-15 on the frame and the floor. Then maybe Herculiner over that on the floor or maybe some of that waterproof vinyl carpet stuff.
  7. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    I'm thinking similar to you. POR 15 on what I can get of the frame and under body, the entire thing when I eventually do a body off resto. Heck, maybe even Herculiner over the POR 15.
    Body will probably get POR 15 on every spot of rust I find and maybe Herculiner on the lower portions of the body. Floor will get at least a coat of POR 15 and Herculiner. Not so hot on those vinyl floor mats. Just one more thing to spend money on and fight with./forums/images/icons/tongue.gif
