frame problem with shackle flip
Discussion in 'OffRoad Design' started by 4wheelingyz, Nov 20, 2003.
  1. 4wheelingyz
    4wheelingyz Newbie
    Nov 20, 2003
    4
    Fort Smith AR
    I got a used 4" shackle flip. Tried to put it on and the bolt holes in the frame and the ones on the new shackles do not line up. I also tried a buddy's shackle flip and got the same results. Any input would be appriciated. Thanks. /forums/images/graemlins/thinking.gif
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    chevy frames flex, its what they do. I got my ORD shackle flip new, and the holes on the bottom of the frame didnt line up exactly right... its no biggie, I just had to bolt the bracket on with the holes that did line up and do a little work with a drill and dremel too.
    j
  3. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    yes you are correct, but to elaborate a bit more on his problem...
    it seems that the shackle flip is pretty much a 90 degree angle (the mounting surface i mean). but his frame seems to have a slight curvature, or bulge, to it. basically, its not mounting up flush with the frame. the flip came off of a 90 model k5, and he is putting it on a 77 or 78 /forums/images/graemlins/confused.gif swb. there should not be any differences in mounting, correct?
    so, might his frame be fubar'd? /forums/images/graemlins/eek.gif
    thanks for the input. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. jackedjimmy350
    Oct 20, 2000
    3,141
    and fill out your profile, a-ron /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    BFH time......
  6. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    nope there should not be any probs. i put a 4" on my 74 no probs. if'n his frame is bowed out there is something more serious going on there /forums/images/graemlins/eek.gif
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    the bracket is stronger and thicker than the frame. bolt it up and flaten out the frame. make sure the frame rails are paralell to each other as well. may have been in a rear ender in the past.
    if someting is bent and it is working fine now then it may not track well after the flip geometry will be working a bit different with the flip on.
    grant
