Frame Repair help
Discussion in 'The Garage' started by 1979jimmy350, Aug 31, 2005.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    The rear body mounts on my frame have rotted some and i would like to fix it before i put the body on. What is the best way to fix these mounts. Should i just weld in some extra metal around the area or should i graft a new section on to the frame
  2. wubba_65
    wubba_65 Registered Member
    Jun 22, 2005
    41
    Alberta, Canada
    I'm in the same boat as you. I bought new frame rails to graft on, but I'm just going to weld on some straps on top to reinforce the current frame. I decided that the trouble of cutting frame and realigning new one wasn't worth it because only the top area of the frame where the mounts went through was rotted thin. The sides and bottom are still good.
    Good luck with yours!!
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    has any body else run in to this problem if so how did you fix it
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  6. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    any body else have any ideas how to fix the rotted out section on the frame? :dunno:
  7. wubba_65
    Jun 22, 2005
    41
    Alberta, Canada
    I got mine fixed now, I decided against grafting in the new frame section, I went with patching the old one. I used a piece of 1/4" L iron (3" wide by 1.5 deep) and bolted it through good metal over top of the rotten section. Then I drilled the new hole for the body mount. Worked like a charm.
    If you want pics, send an email to wubba_65@hotmail.com, and I'll send one of the fix.
    Cheers,
    Evan.
