Frame resto?? need more help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerBoy, May 10, 2000.
  1. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I went back and did a search and read all of the post about liner coating (dupli-color, rhinolining, etc..) I still would like to here what everyone has tried and what they thought of it. I have my frame off and am just about done sandblasting it. I was planning to go with POR-15, for the frame. Then some sort of lining for the inner and outter floor boards. Has any one used any of this POR-15? is it worth it? And which coating should I use. Will one gallon of Rhinolining be enough to do both outter and inner floors? I am also curious about dupli-color does it work just as well as the rest? I am so confused to manny options. Thanks guys...
  2. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    436
    Haines, Ak
    The problem here is that not very many, if any, people have used more than one kind. I've used the dupli color,, how is it? I don't know,, I have nothing to compare it to. It hasn't fallen off, so that would be a good thing,, but I haven't had it out wheeling yet, brushing up against tree limbs, etc..... so I have no idea how "tough" it is.
    I've never even heard of the POR-15 until the other day. I've never even seen another kind of "do it yourself" applied or the results of it.
    Todd 78/87[​IMG]
    Alaska Bound
  3. snidgen
    snidgen Registered Member
    Mar 5, 2000
    47
    por 15 is the [censored] for your frame just remeber its all in the prep work for a durable finish. you could also use and epoxy based polyurathane out of a spraygun for extremly sweet results.
    Peace,love,and 4wd is all you need
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    This is just a shot but one of my cyber friends does industrial coatings for a living I would try to contact him, he may know how all the products stack up to each other!!??
    go here to his web site a nd give him a hollar eather on his messageboard or email. His cyber name is Wulf.
    http://www.blazer-net.com
    PS he is expecting a new born baby any day now so don't know how quick he will be but worth a try!
    Good Luck
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  5. Captkaos
    Captkaos 1/2 ton status
    198
    Birmingham, AL
    Por15....
    I am about to blast my frame and paint it with Por15. A friend of mine (Troy) painted his frame with it http://www.troybaker.com/62stepside. He said it is very tough. He said he was "marking" a line on the frame with an awl and it wouldn't scratch it. He ended up painting his gas tank, inner fenders and core support with. As I understand, it takes a grinder to get this stuff off.
    Here is more links to discussions about it on another Chevy forum:
    http://67-72chevytrucks.com/board/ubbhtml/Forum1/HTML/002413.html
    http://67-72chevytrucks.com/board/ubbhtml/Forum1/HTML/000394.html
    http://67-72chevytrucks.com/board/ubbhtml/Forum1/HTML/000741.html
    http://67-72chevytrucks.com/board/ubbhtml/Forum1/HTML/001214.html
    Their link is http://www.por15.com
    Chris Lucas
    http://www.wwisp.com/~captkaos
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    POR-15 IS EXCELLENT. USED ON 57 BUICK FRAME. ALSO DID WHEEL
    WELLS AND BED ON MY 87 K-5. HOLDS UP VERY WELL AND WON'T
    COME OFF. DO NOT GET ON YOUR HANDS THE WARNING ON THE CAN IS TRUE, ONLY TIME WILL REMOVE FROM SKIN. POR-15 HAS A FULL
    LINE OF PRODUCTS. WELL WORTH THE MONEY. BELEIVE THEY HAVE A WEB SITE, NOT SURE OF ADDRESS. GOOD LUCK.......
