Frame Swap/Blazer K30
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Goose, May 4, 2000.
  1. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I would like to put a frame from a 1 ton vehicle under my K5 and use it's running gear and all. It seems this may eleviate a lot of problems with axle swaps and whatnot, but may create some of its own. From a past post it was said that the K5 frames are different from pickups. Anybody know the differences from a Suburban to K5 frame may be? I'm thinking if I find a 1 ton 4x4 Suburban I could just shortent the frame and put the K5 body on it and have a parts vehicle to boot. Any body have a Sub and K5 they could do some mearsuring on? How about directions to a site that may have some information regarding frame dimentions????? Also, I believe that the 1 ton vehicles have heavier duty frames. Is that true or have I been staying up too late at night thinking about mods for the K5?
    Mud is just thick water, or is it that water is just thin mud?
  2. I have never seen a 1 ton Burb ! There is no problem with most axle swaps, they usually bolt right in, it is the shafts, ect.. that need the TLC. 1 tons do have a more rigid frame, but when you cut it, there goes that strength you wanted. I have an 1/2 framed 88 Burb with 1 ton axles if you still want some measurements tell me want you want/need.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  3. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    I've seen about 3 1 tons in one day!!! I was at a FourWheel Fun Fest in IL and all three ran in the tough truck comp... mann, those things just bounced (very smoothly) over the obstacles... I think one did crap out though. I think that putting one ton gear on the K5 frame will be easier and less discouraging than trying to figure out everything need to do it... maybe a custom frame could be considered???
    NEVER been stuck... *yet*
  4. Goose
    1,127
    I see your point, esp with the 1 ton Burb not being produced. Thanks for the input. The idea is not dead, but not far from it.
