frame swap
Discussion in 'The Garage' started by summit56, Nov 14, 2003.
  1. summit56
    summit56 Registered Member
    Nov 14, 2003
    10
    will a 67 c20 cab fit on a 1977 blazer frame with a 92 stepside bed?
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    it's not a bolt on deal but it can be made to work you would have to fab cab mounts and shorten the bed
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It might be easier to put it on a shortbed frame.
  4. summit56
    Nov 14, 2003
    10
    so if i use a shortbed frame will i still have to make custom cab mounts?
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    almost definetally.
  6. yellowK20
    Dec 26, 2002
    7,603
    555
    Wasilla AK,
    yes because the rear cab mounts on the 70 are on the outside of the frame on the later trucks there on a cross member between the frame rails
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    swap frame mounted body mount brackets for cab from the 67-72 frame, drill holes and bolt with common 3/8" x 16tps hardware
    youll need to use tape measure to find out if cab and bed will fit before contacting the rear tires
