Frame work... (its coming together)
Discussion in 'Pacific Region' started by Topdown, Dec 20, 2004.
  1. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Here is the frame after removing the 36" center section, 11" tail piece and 4" nose
    http://coloradok5.com/photos/showphoto.php/photo/18182/size/big/sort/1/cat/500
    First weld on making the frame one piece again (not including tack welds)
    http://coloradok5.com/photos/showphoto.php/photo/18183/sort/1/size/big/cat/500/page/
    Third weld, a nice long run down the frame rail... not bad even if I do say so myself...
    http://coloradok5.com/photos/showphoto.php/photo/18184/sort/1/size/big/cat/500/page/
    So... now the frame is back in one piece and I have plated the outside and will plate the inside tomorrow.
    -Ryan
  2. mudslinger97116
    mudslinger97116 1/2 ton status
    Mar 13, 2003
    315
    F.G.OREGON
    Ryan i know your building a trugy but what kind of frame are you basing it on ?what are you going to do for a cab?i'm just looking for ideas for when i get off my but and start mine..
  3. Topdown
    Nov 26, 2002
    2,598
    I was given a 1st gen long bed pickup frame, cab and bed. :thumb:
    most of the parts I have been given are in better shape than the ones on my blazer, so as I need/use parts, I am going to replace the ones on my blazer with the better/nicer ones and use the blazer ones on the truggy.
  4. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    im lost?
    WOW....I havent been in here in like a month and so much has changed!? Ryan what are you doing anyways?? fill me in!! I thought U where building the Sami up? are you onto a new project??
    Kevin: Hurry up and figure out what ya wanna do with yers...remember I owe you lots of work on it!
  5. Topdown
    Nov 26, 2002
    2,598
    big negative on the Sammi... I couldnt find one cheap enough (free) and Troy mentioned that he worked with a guy that was taking a couple 67-72 trucks to the scrap yard. So, to make a long story short, I have been picking up parts from him that he is/was going to scrap and building a truggy.
    so far its been the perfect project, I have $0.00 to spend on it and have had to spend $0.00 on it. :thumb:
  6. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    ryan... I assume when you plate it you are using a fishplate or triangle technique so as to not stress the frame...
    nice work on the welding... what process?
    cam
  7. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    Nice welds there :thumb: That little welder you borrowed from me is doing the job just fine I see. I will have to get over there one of these days and take a peak at it in person :D
  8. Topdown
    Nov 26, 2002
    2,598
