Frames
Discussion in 'The Garage' started by mudjunkie 82, Oct 31, 2005.
  1. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    got a buddy who has a 1/2 Chevy pick up that need a new frame installed. He asked me this question about the different years these trucks were made,From78-to 87 are the frames all the same for a 4x4 and do the shortbeds have a shorter frame than the longbeds ?????never delt with these so any thanks for any advice......
  2. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    believe the frames are the same through those years. longbeds have a longer frame. 3/4 and 1 ton have thicker frames
  3. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Do 3/4ton (military) Blazers have the thicker frames as well?
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dont think military k5s have thicker frames....i thought only 1tons had the thicker frames, and 1/2 and 3/4 tons had the same...
  5. natehate
    natehate Registered Member
    Sep 15, 2005
    56
    onterrible canada
    i know for a fact my dads 87 short box with a v6 has a thinner frame then my 90 jimmy
  6. crazyhole812
    Jul 6, 2005
    228
    missouri
    i'm sure my 3/4 ton has a frame that's thicker than 1/2 tons i think i even read that on ORD when i was ordering my steering box brace.
  7. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
  8. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    3/4 ton frames are definately thicker than 1/2 ton frames
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the frames any exactly the same from 78-87, from 73 to 80 the ends were formed to bolt to the bumpers, in 81 they started using brackets that bolted to the frame and then to the bumper. also sometime in the early 80s the rear cab mount changed from a bracket (like the front cab mount) to a crossmember. my buddies 81 has the brackets and both my 83s have a crossmember. i believe the frames are the same shape and should swap with no problem.
    a long bed frame is longer than a shortbed frame.
    with the thicker frame, not all 3/4 ton frames are thicker. i have a 83 k10 and a 83 k20 and they have the same exact frame. most of the other k20 frames ive seen are thicker, but mine isn't. so just because its a k20 frame doesn't mean its any thicker than a half ton frame.
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    the 3/4tons with 56" springs prolly are the ones with the thicker frames, 52" springs are the thinner frames. im jus guessin :o
  11. crazyhole812
    Jul 6, 2005
    228
    missouri
    you're probably correct. mine has the 56" springs
