Freakin Bolts!
Discussion in 'The Garage' started by Me89'Jimmy, May 3, 2004.
  1. Me89'Jimmy
    Me89'Jimmy 1/2 ton status
    Oct 6, 2002
    127
    Sykesville, MD
    im putting ORDs 4" shackle flip on my truck, the problem is the bolt that holds the bottom of the shackle to the bracket WILL NOT COME OFF, ive hit with the impact gun, ive lubed it, ive spent a cans worth of penetrating oil on it, i put a 2 ft breaker bar with a 4 foot pipe extension on it, i can only turn it so far before the corner of the truck picks up off the lift!!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/yikes.gif Who ever said its the little things in life that kill ya must have had an offroad vehicle! (and on a lighter note if someone could make an icon of a smilie face pulling his hair out, i do believe it would fit right in with those already provided /forums/images/graemlins/thumb.gif) thanks for lettin me vent
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    1 word..."GRINDER"
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Time for /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/hack.gif
  4. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    Heat or grinder. Time for get rid of stress through destuctive fun!! /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    [/ QUOTE ] /forums/images/graemlins/waytogo.gif
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a torch works better than a grinder. just stay out of the fumes from the burning rubber. /forums/images/graemlins/yikes.gif
  7. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    It took longer to cut one bushing assembly on the front of my rear spring than it did to completely shave my 14 Bolt...... and 4 sawzall blades
