Free Mods?
Discussion in 'The Garage' started by Confedneck, May 13, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Ok, i know there are free mods for almost every truck, so if you have them, lets see what ya got....
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    fender trimming?
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    umm turning the air cleaner top upside down..
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Remove the swaybar.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> There's the home made shackle flip that people do... </font>
  6. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    What kind of Rig is it?
    Engine?
    Trans?
    T-Case?
    Axle's?
    Etc?
    Then maybe We can help You more. /forums/images/graemlins/blush.gif
  7. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    that does that do?
  8. heavy4x4
    Aug 28, 2002
    3,270
    I've never tried it, but it supposedly makes a cool sound when sucking the air in. As far as performance - well, I'm sure this will turn into a dispute pretty quickly, but it will hurt performance because your engine will be taking in warm air from the engine compartment.
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, fender trim is a good one. You can also do the radiator-hose-power-steering-resevoir trick for free if you have an old rad hose layin around. Shaving a ff14b or calipers is free, assuming you have a grinder or whatever. /forums/images/graemlins/tongue.gif
    j
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    but more air will come in faster... /forums/images/graemlins/wink.gif
  11. heavy4x4
    Aug 28, 2002
    3,270
    Here we go /forums/images/graemlins/rolleyes.gif
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Its allows the potention for more air to be sucked in. Look at the size of the air in take tube, compared to the much larger surface area of openness.
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The flip side is that the air is much warmer, whereas the air from the snorkel will be cooler. COol air is more dense, allowing more air to pack the cylinder. I've tried both ways and it seems to be a wash to the "seat of the pants" dyno. </font>
  14. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I just happen to have a spar hose, could you exsplain?..;.please /forums/images/graemlins/ears.gif
  15. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    oh yeah, forgot the part about how u need a 2nd PS filler neck. At any rate, its just using a radiator hose to make your PS resevoir hold more. Basically you hose clamp a length of hose on the filler neck... and then you hose clamp a 2nd neck into the top of said hose and reinstall the cap in that. Purdy simple and it works really well... you just have to find a rad hose, some hose clamps, and the neck off another PS res.
    j
  16. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    1. Remove top
    2. Disconnect sway bar
    3. If you have a factory dual shock setup, you remove one for better ride/flex
    4. Airing down(although you have to air up at some point, which will cost ya!)
    5. Unplug EGR if it's old/faulty
    6. Remove doors for added visability
    7. Gut the interior for weight and waterproof issues
    8. Play with the timing
    9. etc etc
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Don't use radiator hose. I don't think it will stand up to the PS fluid without breaking down. Gas filler is a better choice...
  18. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Also, be careful unplugging/blocking the EGR. It will cause higher cylinder temps and may cause additional problems with ECM or ESC (including retarded timing).
  19. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    What does the "additional PS resevoir" do for you??
    Do the pumps run out of fluid or is it just for cooling /forums/images/graemlins/confused.gif
  20. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Sawzall before the muffler/s /forums/images/graemlins/thumb.gif
