Free Np241 transfer case!
Discussion in 'The Garage' started by camarossguy2, Jun 15, 2006.
  1. camarossguy2
    camarossguy2 1/2 ton status
    Aug 10, 2004
    214
    ABQ NM
    In about 1000 pieces along I40 in west oklahoma :)
    So im driving from daytona beach Fl to Albuquerque nm towing a civic, and my upper U joint fails at about 70mph...
    Yah it was bad...pics coming soon.
    My question is, i need a new Tranfercase and drive shaft what are my options?
    Find another NP241? or 208? 205? i know the 241 came in the later model K5s like mine, but are they better?
    And for drive shafts... put a rebuilt stocker back in or have one built with a CV or something?
  2. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Is your rig lifted? What do you use it for?
    You most likely will be able to find a np208 faster than a np241. The adapter is the same.
    The 241 has the lower low range(2.72:1), but the 208 (2.61:1) isn't far behind.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what year is ur rig? if its an '89 you have more options. 90-91 is electric speedo and you pretty much can only use a 241 from a 90 or 91 without needing mods. if you have an '89 you have mechanical speedo, and can run an '89 241 or any 208. it also depends on ur tranny. th400 is 32spline, 700rr4 is 27spline.
  4. camarossguy2
    Aug 10, 2004
    214
    ABQ NM
    89' with the mechanical speedo and a 700r tranny.
    I just dont know what th differences between the 205/208/241 etc are...is it just gear ratios, or is one better then another?
  5. camarossguy2
    Aug 10, 2004
    214
    ABQ NM
    Yes, 8'' lift on 38s...use to be a mudder, but now that i've moved to albuquerque, it will be a rocker
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Have fun. Passenger side 241's are a bitch to find and they are usually at least $300. If you can afford it, great, if not, put a 208 in.
    *typo*
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its not a drives side transfer case. its an '89... drops on the passenger side.
  8. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I would do a 208 for an easy quick swap. But 205 if you are going to rock it:D
    A 208 has the 2.61:1 low range, but it uses a chain and a aluminum housing. You can do a fixed yoke kit by using dodge parts, but its not a simple swap.
    A 205 has a 1.96:1 low range, but uses gears and a steel housing. The 205 can take a beating and easily be upgraded to 32 spline out puts and a fixed rear yoke.
