free rear end!!!!!!!!!!!!!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAROLINAK5, Aug 28, 2001.
  1. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    neighbor says i can have an old 3/4 ton chevy truck taht is at one of his friends house, problem/question.......it is a 68 year model truck. what is under that booger and will it fit my 78 K5? will it be worth the hassle of getting it?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    1968....
    i am sure but not 100% that is is coil with wishbone. but i am like 98% that it is. you could make a coilover with it real easy.
    should be a dana70 or so.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Good chance its an Eaton. Looks similar to a big 9" Ford, with a removable rear cover. If it has the right gears and a Detroit, its probably worth it, if not, I'd keep looking. I believe the Detroits for them are discontinued. They did often come with good gears, though.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    Either a D60 or an Eaton!
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  5. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    If it is a 60, pull a shaft and count the splines. 35 spline = keeper, 30 spline = keep looking. I think it would be a 30, but not sure.
    Pete
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    You have to watch too I heard some of the old ones had 19 splines!
    Mike
  7. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    carolinek5- where in carolina?
    i am in greensboro. and there are some others on the board from here.
    later man
    <a target="_blank" href=http://confederate9.coloradok5.com/>confederate9.coloradok5.com/</a>
    <font color=red>K5: Because size DOES matter</font color=red>
  8. not4show
    not4show 1/2 ton status
    Apr 24, 2001
    280
    Alabama
    If it's a 68, then it's an Eaton, and there not worth fooling with. Nobody has parts for these axles anymore. Plus, there a little narrower than a 14 bolt too. So, it has an even worse problem of tracking the front axle.
    Never put a stupid move passed a stupid person. <P ID="edit"><FONT class="small">Edited by not4show on 08/28/01 06:23 PM.</FONT></P>
  9. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    i ahve to eatons id be glad to trade off =-) ones in a 3/4 68 4x4 and the other came out a 57 GMC 2x4 [​IMG]
    AJ
    Soon to wheelin spot near you
    Project Harvey[​IMG]
