Freezer not freezing
Discussion in 'The Lounge' started by hi pinion, Jan 29, 2005.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Ok, i have this maytag refrig.... up until abouit 2 weeks ago, the freezer was working fine, but now,, it dosent want to freeze all the way. The regular fridge part works fine. Reccomendations???:)
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    ok dumb question first.
    isthe nob turn up on the frezer?
    try kicking it.:crazy:
  3. sweetk30
    Nov 1, 2004
    25,537
    534
    horseheads , ny 14845
    also if the fridge is to close to the wall it wont work correctly
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Regular fridge part can't be fine , all the cold air comes from the freezer , if it is a problem it could start getting warmer . I would start with the defrost thermostat , heaters and timer if its older . If its newer I would bet its the adaptive defrost board . The defrost system dictates how often the defrost comes on , and when to turn the compressor back on ..... regardless of where your temp is set at :k5: :k5:
  5. hi pinion
    Sep 25, 2003
    5,354
    Really?? Ill try moving it. Anything else??:)
  6. hi pinion
    Sep 25, 2003
    5,354
    Pauly,,should i unplug it and let it get warm, then plug it back in?:confused:
  7. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Clean off the coils. If they're covered with dust they won't exchange the heat, just like your radiator.
  8. hi pinion
    Sep 25, 2003
    5,354
    Could someone give me a step by step way to do it?? Like easyest to hardest??:)
  9. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    1. move fridge out
    2. clean off coils
    3. move fridge back
  10. hi pinion
    Sep 25, 2003
    5,354
    Oh, and all this time ,,I was thinking there wasnt enough beer in there!!!! :grin: So, do i clean the coil BEFORE i move the fridge out? Or before? :grin:
  11. chevyfumes
    Feb 24, 2000
    38,584
    266
    As a rule of thumb you want to have atleast a 12 pack in the fridge at all times...But thats just the house fride and not including whats in the pantry, now if we're talking shop fridge then your gonna need to bump that figure up to around a case...:grin:
  12. hi pinion
    Sep 25, 2003
    5,354
    Oh,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
    OK!!! Just checking!!!:D So ill just clean the coil,before i run the disk defrangmenter,i hope that works:grin:
  13. chevyfumes
    Feb 24, 2000
    38,584
    266
    Also for the fridge in the shop, your beer to food ratio will have to be right around 75/25 and no girly food either just chocolate and meat products and that old bottle of mezca Mom brought home from Mexico...Let me know if you need anymore help, I'm here for ya man...:grin:
  14. hi pinion
    Sep 25, 2003
    5,354
    NNNNN- KAAAAY!!!! NNKK?? (sounds as its spelt) :D ROLTF!!!! So what else could i do to the fridge to make it work??? Besides cleaning the coil?? Do a meltdown for 2 hrs?:)
  15. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    It depends. How old is the fridge? Stick a thermometer inside the fridge with it cranked to the coldest setting and see what it reads. It may just be time for a new one.
  16. hi pinion
    Sep 25, 2003
    5,354
    Its around 5 yrs old, its a really good maytag.Thanks guys, later
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Was outside playing grind my crossmember with Dave . Get me a model number and I can tell you the most common failures I see . But first do as mentioned by others and move and clean the coils . Also it wouldn't hurt to see if the fan is working down there by the compressor , if its not a household fan will tide you over for now until Monday , ask your plumbing parts guy where to go they can hook you up with a place like mine in your neck of the woods , find the oldest counter guy and treat him nice :k5: :k5:
  18. hi pinion
    Sep 25, 2003
    5,354
    Roght AWWWN AWWWN AAAWWWNN!!! Ill pm ya some stuff:) Sorry just in a good mood today, carry on, Jake:)
