Freezing my Boys Off
Discussion in 'The Garage' started by Mudbug1979, Dec 13, 2005.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    OK, My K5 gets a little cool when the heater won't blow on high. I have replaced the blower motor, dash switch, and the coil thingy in the evap box under the hood. The motor will work fine on 1-3, but when you switch to 4 it dies completely. Whats next, someone mentioned a blower motor relay, but I have no idea where that bad boy is. Help please....... Thanks.
  2. chevyjeff
    chevyjeff 1/2 ton status
    Dec 10, 2003
    118
    WYLIE TEXAS
    blower motor relay is on the top of ac box. 4 wires in a rectangular type plug.
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    what temp thermostat you got in there? If your truck is running too cool then you wont get barely any heat in the cab. When you turn your heater on high like that all your doing is cooling down the coolant even more therefore on high thats why you get cooler air. I had this in my blazer and from what I remember I went from a ~170 to a 195 degree t-stat. That seemed to help alot, especially on high the air was much more warm. Ohh and that is providing that your heater core is allowing enough flow through it too. Which is another possibility.
  4. Mudbug1979
    Aug 4, 2002
    439
    I'm running a 195 degree, but the thermostat is working properly. The motor only runs on 1-3, not HIGH. I replaced that relay then, the only other thing I could be is the resistor on the front of the blower motor. If anyone else has any ideas it would be greatly apperciated.
  5. Mudbug1979
    Aug 4, 2002
    439
    Anyone?
  6. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    at least you have a heater. mine does not work at all. Still trying to figure out the wiring. When i purchased mine the wiring was gone.
  7. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Have you checked the switch to make sure you are getting voltage on high? I have had switches go bad at one location only.
  8. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Yep, had that happen too.
  9. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Check the switch, and check to see that voltage is getting to the blower motor when it's on high. if it is, it's something at or in the blower motor, if not, check everything in between.
    Could it be a bad ground somewhere too?
  10. Mudbug1979
    Aug 4, 2002
    439
    Is there anyway that it could be the Resistor that is on the outside of the blower motor. I have changed the switch 3 times and still no high. I'm outta ideas, anyone else.
  11. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    maybe...resistor is easy to change at least...
    I'm not sure if the resistor is even "in the curcuit" on high speed or not..:confused:
    Here in MA,it gets so cold I use only "HI" or nothing at all--so if my truck had a dead resistor I wouldn't miss the other speeds...in fact,all GM trucks from 73-87 have a "continuous running blower" --that means its really "on" at "low" speed when the switch says "off"!...
    I learned this when my blower motor decided to sound like a seized bearing at 10 degrees one morning--scared the p*** outa me,I thought it was something serious!..had to put up with that chalk on the blackboard noise every cold morning until the blower motor heated up some--if I put it on high it would go away faster!--
    I drilled a small hole in the motor housing where the shaft is,so I could add a bit of oil..then I snipped off the wire that had power when it was on "off" that made it run constantly!;)
    Many of my trucks I just put a fused 12V hot wire from a toggle switch directly to the blower motor so it would only run on "high" speed..I found it wound out a bit faster that way..an A/C equipped blower motor has a bigger fan and spins much faster than a non A/C one,and they are a bolt in swap!..many GM car blowers are the same too..I usually swap one in on my trucks..nothing worse than an anemic heater in cold climates..:mad: :crazy:
  12. Mudbug1979
    Aug 4, 2002
    439
    Which wire should I hook up to a toggle switch so that I can turn it on high when ever I want???? Thanks.
  13. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    make sure you have 12v to the relay with the key off(not sure which wire, probably a big red one...), if not, that is the problem
  14. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    heater switch by-pass
    Just use the wire coming directly out of the blower motor housing if you feel you must by-pass everything with a switch.(its sometimes a black wire,don't be fooled into thinking its a ground wire!--it plugs onto a "spade" connector sticking out of the motor housing--a rubber bootie is made onto the wire..sometimes the wire is orange too,its different on some years..
    Its nice to keep everything working the way it came from the factory though,if possible..its easy to replace the relay and resistor with new,or cheaper used junkyard parts if they are suspected of being defective..might go that route first!.
    I use toggle switches on my 20+ year old plow trucks--yours might be nicer and newer than mine,you might not want to go the "crude but effective" route on your truck.... :)
