Fresh 350 shortblock
Discussion in 'Engine | Tranny | T-case' started by big4x4ride, Dec 18, 2005.
  1. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    have a 350 chevy 2 bolt main shortblock
    block is standard bore, was cleaned, linbored and miced, said to be good to go.
    speedpro h345np flattop 4 valve relief pistons 9.64:1 with 64cc heads
    summit 1103 cam 214/224 .442/.465 at .050 272/282 adv duration
    brand new melling oil pump and pick up
    rods were all resized and cleaned
    federal mogul main bearings, sealed power rod bearings and rings
    this is all installed and brand new
    along with this you will get the entire felpro gasket set, oil pan, new pushrods and lifters. water pump with 50 miles on it. vacuum advance distributer with 10 miles on it, alternator with 50 miles on it, balancer with 50 miles on it.
    Basically you will need to get some heads, intake, carb plugs and wires.
    About $1000 invested in the parts and machine work(machine work was $304 alone) take it all for $525 FIRM
