fresh air pvc vavle..
Discussion in 'The Garage' started by bryguy00b, May 26, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    you know that breather tube on the pass side cyl. cover...well i have an aftermartket open elemnt type air cleaner on my carb and the fresh air tube doesnt fit on it..is there anything i can do about this?
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    The air cleaner should have come with provisions to hook up all emission equip. Should be a fitting on the bottom of the air cleaner for the tube or hose to slip over.
    Jim
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    there is but it doesnt fit..but ive seen like seperate air cleaners liek small ones on these i think befor..
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can get a small K&N breather filter to go there.
  5. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Mr. Gasket makes shiny chrome ones that come with a new grommet for about $5. check out AutoZone
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    oops /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif
  8. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Use a piece of hose as a sleeve to connect the two.
    Jim
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well i bought an open element air cleaner for it but its to big and i need to get a smaller one but dont have time tonight..and the gormet from the origional pcv vavle tube broke so i cant put it back in..is it ok to drive it with out anything on there? cuase i have to get to school tomorrow...or is it not a good idea?
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    anyone know the size of the hole on a stock 350 vavle cover for the breather?
  11. SCOTTS_4X
    SCOTTS_4X 1/2 ton status
    Mar 22, 2002
    129
    Modesto CA
    there should be a breather on one valve cover and a pcv valve that hooks to manifold vacuum on the other. you are hooking your pcv valve to your air filter? I'm confused /forums/images/graemlins/confused.gif
    -Scott
  12. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    urr..no..lol its the crankcase vent thing on the pass side cylinder cover..that long breather tube that hoo kto the air cleaner..i took it of to put a filter on it instead trhat plugs right into the hole..but its to big..and the gormet that the old tube went in broke..so i have nothing there right now..and i wanted ot know if it was ok to drive it tomorrow just to get ot school and back wiht out anything on there..would it do any damage?
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
