friend/coworker dodge avenger problem.
Discussion in 'The Garage' started by vortec, Apr 3, 2007.
  1. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    double check me here
    a friend's 1997 avenger is running weak and when she hits the brake, it stumbles or dies. my first thought: vacuum leak, possibly at the manifold gasket, throttle body gasket, vac hoses, etc. i haven't seen the car while it's been acting up.
    i told her to run through the gears and tell me what happens. stumbles/stalls in all gears, but park. when i had her press the brake while in park, it did stumble to. so, to me, it's obviously a vacuum issue.
    she doesn't believe me, though. other thoughts?
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    possible bad booster
  3. 1979chevystepside
    1979chevystepside Registered Member
    Feb 5, 2006
    46
    Huntsville AL
    420a motor?
  4. vortec
    Jul 22, 2004
    1,472
    fort worth, texas
    2.5L v6 engine code "N".
    she says her dad used to be a mechanic or something, and has been screwing with the car for 2 days with no luck. he's convinced that changing the spark plugs/wires will fix it. i really doubt that.
    but, her dad is the same genius that swears you can't run dual timing chains on a smallblock v8, even after his daughter showed him pics of my 350 before i installed the timing cover. he claims my engine must not be an sbc. :haha: :haha: :haha: is it that hard to say, "oops, i was wrong"? what a dufus!
