Friend needs help with Death Wobbles in a 2wd!?
Discussion in 'The Garage' started by Eric M., Oct 10, 2006.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Can anyone point me to a site that might be able to help my buddy out? He's got a 2wd, 75 GMC dually that experiences death wobbles at about 80 MPH. Yes, I told him a 75 GM dually was never built to go 80, but, he's owned it for years and it never Wobbled before.
    All the front end is new, new steering box, alum. Weld rims, he's tried several sets of tires.
    I've never heard of DWs on a 2wd :confused: and I've got three 2wd 1 tons with about 200K miles on each.
    HELP!!!
    Thanks,
    Eric M.
  2. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    At first I thought death wobble didnt happen on 2 wheel drives but for some reason a couple of my work trucks (99 or newer F-350's) have been getting it really bad and at freeway speeds none the less. All I know is that its cause by bad harmonics in the front end. Not sure how to fix it on a 2 wheel drive other than making sure everything in the front end is in good working order and if that dosent work try adding a steering stabalizer.
  3. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Centrimatics maybe?
  4. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    What's that?
    Eric M.
  5. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    tires? radial or bias?
    also any severe chopping or possible belt bad. not real comon anymore but i would not second guess on a dually 1ton.
    play in the steering box ?
    possible rotor cracked or brake hanging up.
    and is it in the steering wheel ? = frt problem
    or in the floor or seat? = rear problem.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I had a 2wd LUV that had DW and it turned out to be the TRE were worn out allowing the wheels to move somewhat independently.
    Ira
  7. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks,
    Eric M.
  8. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    are the shocks good? if they're new, are they cheap shocks?
  9. Slapperbar
    Nov 29, 2005
    2,747
    3
