Friend
Discussion in 'The Garage' started by Tshane, Jan 27, 2003.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    d
  2. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    Re: Friend with AMC 20 axles LOL
    he running 35" boggers
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    His Jeep is a lot lighter than a full-size GM truck. /forums/images/graemlins/wink.gif That alone will help a smaller axle live. (But I have seen guys snap Dana 60 shafts on a CJ before!)
    The AMC 20 is actually a pretty stout axle, other than the stupid 2-piece axles. Swap in a set of Summer Brothers one-piece axle shafts and a 20 will take an amazing amount of abuse. /forums/images/graemlins/cool.gif
  4. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    The axles probably wont last very long. It just depends on how heavy his right foot is. A friend of mine had a AMC20 in his heep with a straight 6 and 31" tires and snapped one of the stock axle shafts. So he spent about $300 and got some good solid axles from Moser engineering. He systematically broke the everything else, but never another rear axle shaft /forums/images/graemlins/cool.gif.
  5. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    The AMC20 in the rear of a CJ is about on the same strength level as a D44. He will be fine. Yes, he is correct, a 14b with just 33" tires is way overkill. You are giving up a ton of ground clearance with such a large diff and small tire. I hope you plan on having some stout diff sliders. I bet a stock 10b would hold up to your 383 and 33's.
  6. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    1st it would be the AMC20 axle (not axles, there is no 20 front, it should be a D30).
    2nd I would rather have an AMC20 w/ one piece shafts on 35s than a FF14B on 33s. Even more so if the 20 is in a CJ. Just a note;The 20 has a bigger r&p than a D44.
  7. Grim-Reaper
    7,385
    Atlanta
    2 peice axle shafts won't last long but once he puts in one peice it makes a pretty decent axle.
    I was standing next to a friends Scrambler when the splines cut loose on a 2 peice. Pretty interesting noise to hear as the splines and keeper turn to dust /forums/images/graemlins/smile.gif We put a 3/4 drive ratchet on the nut and a high lift handle and jumped on it for a while. Held long enough to get him out. Done the same trick on a couple of jeeps as a matter of fact. /forums/images/graemlins/smile.gif
    1 ton on 36 and under is over kill especialy on a jeep.
  8. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    yea its a dana 30 in the front
