friends 6.2 surges when on the governor, cant go through emissions.
Discussion in '1982-Present GM Diesel' started by moturbopar, Jan 5, 2006.
  1. moturbopar
    moturbopar 1/2 ton status
    Feb 9, 2005
    387
    mesa az
    Hi all my friend bought an 83 suburban 3/4 ton with the 6.2. The thing has a newer engine and a banks turbo kit. The problem is that the engine surges at full throttle in nuetral. As soon as it hits the governor it revs up and down slightly. The problem with this is that the the emissions station said thay wont test it since its doing this. Is there a way to tune this out? Is there something wrong that needs to be repaired?
  2. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    I'll display my ignorance of emission testing - What kind of test is full throttle on the governor in neutral supposed to be?? That's crazy!!
  3. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    this doesn't really help w/ your initial problem, but i just thought i'd add this. when i go to do emissions, i'll be filling up with biodiesel b/c nothing burns cleaner than biodiesel. no mods necessary on your truck either. it's pretty pricey from the pump, but you only have have to do it to pass, right? here in oregon it's almost $3/gal. you can look online to find out where you can buy it down there.
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Put a 1" "HIDDEN" stopper/block on the underside of the gas pedal so they cant reach the governor, there remove it after testing
  5. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I run a stopper block on my gas pedal linkage underneath the dash. Limits the throttle to about 60-70% of max. I did it to help get through the emissions testing here. My truck has a manual tranny, so on the dyno they would always shift too early, then floor it and the opacity would spike while it lugged. With the throttle stop on it it passed with flying colors even with stupid driving...
    For whatever it's worth the stop is still on the truck...I don't need that last part of the pedal for much of anything anyways. If I towed with it I would remove the stop though.
    Rene
  6. moturbopar
    Feb 9, 2005
    387
    mesa az
    well we kept the throttle from going 100% and it passed with flying collors actually had 0% opacity.
    Thanks guys
  7. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
