Friends, Countrymen, Romans, Lend me your vibrations stories!
Discussion in 'The Garage' started by Leadfoot, Jun 3, 2003.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    and No Wes, it did not say vibrator stories...... J/K /forums/images/graemlins/thumb.gif
    Most of us know that unbalanced wheels, bent rims, improper pinion angles, improper alignment, and unbalanced driveshafts can all cause vibrations.
    What I'm looking for is oddball cases of vibrations as I have checked all of that and still have a vibration. The truck is a 78 K10 with stock driveline 350/350/205/10 bolt/12 bolt/3.08's/and 31x10.5R15's. The truck is clean (no mud globs causing a vibe). I never had a vibe until this last winter. Tranny went out and was replaced along with rebuilding the t-case. "Supposedly" the tranny or t-case is not the cause because there is no sound, which the "experts" said there would be if one of those were causing that much of a vibe.
    I am wondering if any of you have had a warped rotor, drum, axle, etc. that caused a weird vibe or anything else not listed above. Thanks in advance.
    Chris
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What about the tranny mounts?? /forums/images/graemlins/confused.gif
  3. Leadfoot
    Nov 28, 2000
    3,112
    Oops, forgot that too, but the tranny and motor mounts are less than a year old and I checked them to be sure (still like new). Also the vibration came several months after replacing them, so they aren't "likely" to be the culprit.
    Also too, I'm wondering if poor mounts would cause a vibration? I know they will produce a clunk when going forward to reverse or accelerating and decellerating, but would they actually "cause" a vibration?
  4. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    well i had a vibration about three weeks ago. i couldnt
    figure out what it was . checked everything driveline
    related. i even pulled the torque converter cover off
    and checked the converter bolts. well i kept driving figuring something will sooner or later break , then i would
    know. i went up to pick-up my 14bff and on the way back ,
    the truck broke. i found out my vibes were becouse the
    flexplate was breaking right at the center which i could
    not tell. so after a tow home and three hours of my
    time , i replaced the flexplate and problem solved!!!
  5. Leadfoot
    Nov 28, 2000
    3,112
    Well that gives me something to look at.......
    Also forgot to mention u-joints are new as well.
    Thanks for the input.
  6. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    The mainshaft in my transfer case (241) was bent, causing a vibration. The transmission shop didn't catch it when they rebuilt the transfer case, even after I suggested it might be the problem(of course a 19 year old kid couldn't be right). This probably is not your problem, but it is an oddball.
  7. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I rotated the tires on the wifes old mini-van /forums/images/graemlins/blush.gif once and got a bad vibe, We checked the balance and all was fine, we put the tires back in there original spots and it went away. Then I replaced the tire.
  8. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    i replaced most of my body mounts /forums/images/graemlins/smirk.gif i haven't gotten to the pass middle one, which was rusty and isn't even there right now. that sure does cause my rig to vibe, but more like a wobble than a vibe. so i'd check your mounts but if you feel a "vibe" than i'd check the flex plate like scrappyk5 said /forums/images/graemlins/thumb.gif
  9. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I recently had one of my blades on my clutch fan break causing a pretty bad vibration. Mine was obvious, but maybe yours could have a bent blade or out of balance? One symptom of this is vibe increases with RPM, but I would think cracked flex plate would be similar.
  10. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    74
    Humboldt/Pacifica, CA
    Does the vibration happen at a certain speed or does it get worse with speed?
    I just replaced a hub because the inner race was loose and spun - obviously the bearing was dry.
    Also check for badly worn ball joints, and tie rods ends.
  11. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    ive had a bent flywheel and that caused some serious vibes
  12. Leadfoot
    Nov 28, 2000
    3,112
    It is not RPM dependent (so I ASSume that rules out cracked flywheel or bad fan). I checked yesterday by putting the truck in N going down the highway. The vibe is directly related to speed. The problem is sometimes it seems worse than others (starts at about 40 MPH slightly noticeable and gets worse as speed increases). The truck almost feels like it moves quickly side to side (like a bent rim), but the rims are straight (checked and used another set entirely to rule that out). I was thinking a bent hub, rotor, drum, etc., but not sure it would cause that much of a vibe, also how'd it get that way.
    I'm going to keep looking.....I will post if I find out what it is
