From 208 to 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4xmac, Jun 25, 2001.
  1. 4xmac
    4xmac Registered Member
    May 1, 2000
    82
    Calif. Oceanside
    For those of you that have swaped out your 208 for a 205 t-case, were you able to keep your 208 shifter or did you have to use the shifter and linkage from a 205.
    MAC
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I haven't done that particular swap, but I think that you'll need the shifter from the 205. The shifter on a 208 bolts to the floor and has linkage to the case. The shifter on a 205 bolts directly to the side of the case and just sticks up through a hole in the floor.
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That and the NP 205 has a totally different shift pattern. I'm not even sure of the pattern, but my friend's '79 F150 has a 205, so I remember it's different. I believe with a 205 you push forward to put it in 4wd.
    NP 208 is:
    2 HI
    4 HI
    N
    4 LO
    The thing won't let me move them over, but pretend that neutral and 4 low are moved over to the right a little, because you've got to push it over a little to get to those two.
    Tim
    '84 Chevy K10, lifted, loud, fast, and 3/4 ton axles<P ID="edit"><FONT SIZE=-1>Edited by 84_Chevy_K10 on 06/25/01 06:49 PM (server time).</FONT></P>
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i would advise a twin stick shifter for your 205 anyway. better controll of your rig in a tight situation.... : )
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
