From D60 SRW to DRW front hubs ?s
Discussion in 'The Garage' started by Puckett, May 15, 2006.
  1. Puckett
    Puckett Registered Member
    Jan 11, 2005
    13
    Independence KY
    I want to run my H1 8 bolt double beadlocks and 36" Military OZ tires on my 86 CUCV, so I think going to the DRW front hub will be the most economical way to get the crazy 7" backspace to work. Will I need to replace my brake rotors in front when I do this? Also not much is said about the rear axle, is there a dually hub for the rear (14BFF) that widens the trac, or do I have to go spacers?
    The SRW huns are held onto the rotors by the wheel studs, which are larger than the bolts that hold the DRW hubs to the rotor. Most people are trying to go the opposite way as I am, from the DRW to the SRW, so its not something I have seen asked. I would imagine I will have to go w/ the DRW rotors though. I assume the calipers and pads will work with either the SRW and DRW rotor/hub setup as well, correct?
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    You are correct, the rotors with go from DRW to SRW but not SRW to DRW. The SRW stud holes are larger than the same holes on a DRW rotor so it will not self center on the DRW bolts.
    For the rear you will have to go with either wheel spacers or a D70HD from a 73-87(91) Chevy dually pickup to make the track widths similar. The stud flange on DRW bearing hubs is inboard more (about 2"~2.5") than their SRW counterparts, using these will give the axle a narrower WMS.
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Wanna trade those SRW's for DRW's????
  4. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    i will trade as well even will pay shipping both ways
  5. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I dont know if it will help but heres a pic of my crew cab, was a dually, has a 70HD rear with the hummer 12 bolts...cant help but to pic whore a little bit, I just finished the lift and tires this weekend. Well almost finished...
  6. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    nice when are those tires gonna grow?
