Front 10-bolt & Warn axles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jkuvaja, Jan 17, 2001.
  1. jkuvaja
    jkuvaja Newbie
    Aug 8, 2000
    3
    Finland (Europe)
    Hi,
    Is there anybody who uses a WARN high strength alloy axles in front corporate 10-bot?
    The weak point in 10-bolt is short outer axle shaft, typically U-joint blow up and broke a shaft yoke.
    Warn says that this will not happen in they high strength alloy axles.
    Is that just of waist of money, should I go stronger axle? Any suggestions?
    Janne & Blazer K5
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Well, I think warn is blowing smoke up yer butt. I have never seen the front shafts actually break, its always the ujoint and that kills the ears on the shafts. Unless you catch it the second it happens the ears on Warns shafts get torn up also. I am sticking with stock axle shafts. I have heard that Warn warranties any breakage and then I have also heard that Warn will not warranty the ears being trashed because of a broken u joint. For the 5 to 600 bucks the Warn shafts cost, I am gonna stick with stock ones from a Junk Yard, for me they are around a hundred bucks a set for all 4 pieces.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <A target="_blank" HREF=http://depdogsk5.coloradok5.com>http://depdogsk5.coloradok5.com</A>
  3. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    This would probably be a good question to ask on the Off-Road Design forum as they sell these axles and were running them on their shop Blazer.
    The biggest problem is that the u-joint strength stays the same and becomes the weak link when using the chromoly Warn axles. However, Warn also offers fusible clutch rings for the locking hubs which makes them the weak link.
