front 10b and 38's???
Discussion in 'The Garage' started by 85mudblazin, Jul 4, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    front 10b and 38\'s???
    I am wanting to get 38"s and I know the rear 10b wont stand up so I am swapping in the 14b but I cant really afford a dana 60 so will the 10b be able to hold up to 38"s??
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Re: front 10b and 38\'s???
    TILL YA TAKE UP THE BIG ROCKS /forums/images/graemlins/waytogo.gif
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    convert it to 8 lug /forums/images/graemlins/thumb.gif
    He could convert to 8 lug to make wheel shopping easier but it wont make the 10 bolt an ounce stronger..
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    In order to match his rims with the 14bff, he will have to do that unless he gets a d60.
    I didn't say anything about strength
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    so how will the strength be with the bigger tires?
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    What kind of tires are you getting? If you get something like a TSL with LOTS of grip/traction, you will be more prone to breaking an axle because all the leverage the tire is putting on the axle. If you don't wheel hard you could probably get away with it
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    maybe like IROKs with the lightest forged AL rim money can buy... and good aftermarket shafts/joints...
    oh, and no hardcore rocks or heavy right foot action either...
    j
  9. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah ya gotta watch it. I was playin in some mud down on the beach last night.. something went bang haven't taken anything apart yet. U-joint is fine, and the diff is OK, but either the hub or the stub shaft is gone. Will post pics tomorrow. I'm runnin 37" SSR's with an 8 lug 10b front
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it all depends on how hard you are on it. if you use lots of the skinny petal then it WONT hold up but if you use some fines to get up and over things you can make it work for a while
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine didn't even last that long......I broke my 10 bolt twice before I ever even went and played in the rocks.
    38s + 10 bolt = failure 50% of my wheelin' trips.
  12. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    So far I run the same set up for the same reason, the dana 60 is just too freaking expensive. Anyway, I try to take it easy on the front 10b but there are times when I have to really dog it as well, I think as long as you don't wheel like a maneak and only really get on it when you have to you should be fine. Mine has held up for over a year now.
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I think back spacing and how wide your wheels are come into play also.
  14. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    I'm running an '89 Jimmy w/ a 10b front, a tru-trac posi and 38.5s. I've done a good bit of mud & trail riding and haven't had any problems, but I've also been careful not to push it. I do, however, have a D60 I'm putting together to replace the 10b. /forums/images/graemlins/thumb.gif
  15. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    There's a kid locally that runs a 10 bolt 12 bolt in his Jimmy and runs 38x12.5 TSL's and hasn't broken anything yet. He's been running that setup for a few years. Granted he only has a limited slip in the rear and the front is open.
  16. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I have never had anything larger than a 10 bolt or d44 in the front and have run up to 40's without a problem. I only drive in the mud though (no rocks) with a tired small block and open differential. My friend broke a u-joint on a d44 axleshaft once, but the joint had been dry for quite a while and didn't even have any needles left in it. It seems like when parts are in good condition they tend to stay together better. I use the the greasable spicer joints in my axleshafts so I can "push" the water from them.
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    they aint cheap, believe me I had to save pennies for a while to get mine... but in the long run if you really plan on wheelin ur rig, the d60 is cheaper. Replacing busted 10b shafts, joints, hubs, etc etc every trip out gets $pendy eventually...
    j
  18. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    [/ QUOTE ]hell thats what mine was to but w/ 35s [darn] the 10 bolt save for a dana 60 but if you want the 8 lug conversion I have one for sale
  19. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    how much you want for the 8 lug conversion?
  20. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I run 36" Iroks(mind you they are as big as my friends 38.5" TSL SX's), with an ARB and a stock front axle with 5-760x joints and warn hubs with lots of rocks and skinny pedal and havent broken a thing. front 10 bolts are under-rated, especially if you know how to drive right.
