Front 10bolt pinion seal leaking How to replace.???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Monster, Jan 22, 2004.
  1. Monster
    Monster Registered Member
    Jun 14, 2002
    68
    New Jersey Warren county
    My front 10bolt pinoin seal is leaking.I know how to change it but how much do you torque the nut down for the yoke.???
    Thanks.
  2. dyeager535
    26,980
    Are you sure the nut itself isn't just loose?
    Almost impossible to "do it right" once the crush sleeve is set, on mine I went "tight as I could with a ratchet" and it has been fine (actually about three times on one axle, and once or twice on a similar GM car axle) but typically people will say to count how many threads are exposed before pulling it.
    Maybe mark the relation of the nut to the pinion so you can get them back to exactly the same spot, but even then, it's not the "right" way, which would involve testing the preload.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The best way is to test the preload before you take the nut off and then match it.
    I am lookign for an inch/lb torque wrench that is not the click type so I can do that on some of my leaking axles.
    /forums/images/graemlins/thumb.gif
  4. Monster
    Jun 14, 2002
    68
    My mechanic told me to use a 3/8 ratchet and tighten it as much as I could. So that’s what I decided to do. Hopefully my 10bolt does no blow up. /forums/images/graemlins/grin.gif
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    The 3/8" thing, that's what I did and the nut backed off whild driving, locking the rear axle destroying it...
  6. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    if you tightened it with a 3/8 ratchet, take a hammer and centerpuch and hit the part of the nut that is smooth, so it squishes against the threads, that will help keep it from coming loose
