front 203 driveshaft is showing splines.. hmm..
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Sep 16, 2002.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ok under the 79 K10 ther eis about 1" or 1.25" of splined end of the front shaft showing- where the front and rear halves slide together, and it is loose there i can wiggle it all side to side a bit, seem like the shaft is overextended ? the truck doesnt appear to be lifted, only has two regular leaves up front plus another underneath the other two with curled wavy ends.
    the sahft has a CV joint at the T case and another shaft came with the truck and has no CV joint., what is correct for a 79 K10 with 203 and auto ?
    thanks for anything.
  2. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    we see alot of guys with no lift ditching the c/v but it takes a special set of u bolts to use these and make them interchangeable- Jess
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    this shaft that looks overextended does have CV joint
    is overextended if any splines are showing like that right ?
    thanks
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    shaft actually on the truck has a CV, but tons of splines showing where thew two half shafts slide together.
    bad or good ?
    thanks
