front 52' Q
Discussion in 'The Garage' started by jones, Apr 22, 2007.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    I just recently saw a thread or post in here asking the question of axel relocation but search turned up nothing, so help would be appreciated.
    Is it necessary to relocate the axel forward(1.5"?) when swapping 52's to the front?
    Is it possible to retain the stock axel location?
    What are the pros/cons to retaining the stock location?
    I realize that cross-over is ideal, and will probably eventually happen. But not in this stage of the project.
    Thanks for tolerating yet another "52 swap question":D
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    It's not absolutely necessary to move the axle forward.
    If you keep the stock axle location, you can use your stock steering but I really wouldn't recommend it.
  3. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
  4. jones
    May 17, 2004
    379
    IONIA,MI USA
    why is it not recommended? I didn't see anything in the 52" swap thread that answered my question. I read them all before I posted, but I'll look again,thanks.
    I'd be doing it for lift more than flex, since there are virtually no rock gardens for crawling in Michigan. We've got mud,sand,and two-tracks.Some flex would be nice,but extreme flex isn't needed in my situation.
  5. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    your going to have lots of flex with the 52" springs. when you have lots of flex, stock steering will not allow you to steer, since the draglink is so short. it can be done, but your really limiting yourself.
  6. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    If you don't need extreme flex, then you don't need 52's. A set of 4-6 inch lift springs would be a much better bet. Cheaper and easier in the long run.
  7. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Yea, what he said up there ^
