front 60 extended brake lines.
Discussion in 'The Garage' started by spoolnaround, Feb 5, 2003.
  1. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Those of you that have put in a 60 what lines have you run? Brand and length? I was on Russell's web page and they dont list a K30 line for anything longer than a 4" lift WTF? What have you guys done? Do I need to have them made? Right now I have my lines from my D44 on, they work to move it around but I dont trust them and need them for the rear discs any way. So what have you guys done?
  2. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I did SFA swap in 88 SWB.Used stock lines for late model 2WD GM.Have to measure them to see how long,but,was plenty for mine.Lift is about 6-7 in.and they hooked up right on Ford D60 calipers.Factory lines wouldn't reach,mabey just to move it around,but,were tight at rest. /forums/images/graemlins/thumb.gif
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I got some extended lines from skyjacker. They seem to be fine.
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I have the Skyjackers also.
    Got them from 4WPW.
    They are supposed to be for 6 - 8" lift. I didn't measure them, but they look plenty long.
    -- Mike
  5. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    Same as TX Mudder, worked for me!
  6. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    The part number for an Explorer Pro Comp kit that includes a rear line for a 14bolt FF is 7220. The front lines measure 28.5" OVERALL(from the end of one fitting to the end of the other fitting). I do not have them installed because of many other things to do. The rear one is 21.25" OVERALL and not installed either. This kit was $90.25 through a local dealer.
    I have been told that the lines from an '84 1/2 ton 2WD Suburban are about 23" long and will work on the D60 also. I was also told you will need a couple of extra nuts to secure them at the frame end as they do not clip in the way the stock ones do.
    BTW, I am doing all this to an '86 K30.
    LOL
  7. Shagnaz
    Shagnaz 1/2 ton status
    Jul 19, 2002
    308
    South Carolina, North Charleston
    I had the 60 lines lengthened to 30". That is 30" of
    hose and not including the ends.
    $60 was the total.
  8. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    Shagnaz, did you go with rubber hose or stainless?
    This is for the front 60 not the rear. 4WP said they didnt show anylines for a 60 front with 6" of lift! /forums/images/graemlins/rolleyes.gif
  9. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I did a combination of pro comp hoses and then built a bracket to mount them under my frame. the bracket moved them 4" closer to the axle(allmost like havng 4" longer lines). I built my bracket out of a pice of angle iron(very easy).I am runig 5"s of suspention lift and have a 30 degree RTI score near 1000 point and I have never had a brake line to tight.
